2nd Gen R59 Roadster Award for the shortest tire driven!
Discussion in '2nd Generation: 2007+ R55 through R61' started by TG., Apr 23, 2016.
  1. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    Just got brand new tires mounted this morning.
    Actually the Mini still had its winter wheels on so I took my other car to have them mounted and I spent quite some time swapping the wheels myself.
    Then went to do grocery shopping. 5 miles round trip top!
    On the way back . . . psssssss :mad5:
    [​IMG][/URL][/IMG]
  2. 00Mini
    2,050
    Now that's a bummer !! Is it repairable ??
  3. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    I don't know... the key is pretty big. It's nothing similar to a nail. I got the tires from TireRack so I'm hoping they'll replace it with their free road hazard insurance I got.
    I just can't believe the timing, though the tires being new and super sticky, I wouldn't be surprised it played a role.
    10,034
    Thank goodness for road hazard. Of all the things I've seen stick in tires that one takes the cake.
  5. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    Same here. I couldn't believe it when I saw it... is that a key???? I have not taken it out yet until the warranty process gets in the way but I'm curious to see what's on the other end.
    10,034
    I wonder if there is an ignition switch on the other end.
  7. Red Bull
    Red Bull Active Member
    Aug 9, 2014
    525
    208
    That sucks!... rear tire?
  8. Metalman
    7,659
    The key thing to ponder....
    You most likely won't have a key ever puncture one of your tires again in your lifetime....
    That's the keynote to consider for this situation...
    I'd still check with the tire guy to see if he can fix a keyhole...:idea:
  9. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    #9 TG., Apr 24, 2016
    Yes! how did you guess?
    Maybe I should go see a blacksmith instead :lol:
    Better not! :eek6: but I am curious to see the shape of the key and how pointy or not it actually is.
  10. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,371
    883
    physician
    York, Pa
    Nails, screws, (keys), etc. wind up in the rear tire 90% of the time in my experience.
  11. vetsvette
    That in all probability destroyed multiple ply wires on the inside of the carcass. Road hazard should fix it for ya.
    I built tires for Goodyear for 12 years before I retired for the last time and learned a lot about tire construction in that time. A tip... if you find a screw in your tire, unscrew it. Don't just pull it out. Less chance of damage to ply wires or belt wires in the tread package. Maybe if you unlock it before removing it? :D
  12. 00Mini
    2,050
    Unlock it ...... That's funny !!!!
  13. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    Is that a right hand or a left hand turn?
    Good tip about the screw/bolt.
  14. DneprDave
    1,500
    The Discount Tire road hazard coverage is very good. My wife got a flat on a two week old tire and drove on it too long. They gave us a new tire, no charge.
  15. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    I couldn't resist:
  16. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    #16 TG., Apr 24, 2016
    By the way... question:
    Does the tire monitor system goes away on it's own after a while?
    I mounted one of the winter wheel for temporary use, and reset the tire monitoring system. But it still shows as low tire pressure. :confused:
    EDIT: Never mind. I didn't do it properly the first time. You have to wait for the reset message to go away by itself before doing any thing else.
  17. Metalman
    7,659
    ACE is the place with the helpful hardware folks....
    Now find the strong box that fits that key.....
    Could be early retirement.... So git that wheel re-tired...
    With the road hazard...
  18. ScottinBend
    2,547
    Wow......that's a new one!
    Rear tires get more flats cause the fronts kick up the debris off of the road and the rears have to deal with it as best they can.
    Still want to find out what happened to the rest of the front door.......;)
  19. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    Poor Poor MPSS
  20. whaap
    whaap New Member
    Jan 10, 2014
    515
    313
    Tucson, Arizona
    It could always be worse. Once I saw a 'spark plug' in the rear tire of a motorcycle.
