Interior 1st Gen 02 Emergency Boot Latch Cable Retrofit Tutorial Needed
Discussion in 'Tuning and Performance' started by minsanity, Aug 2, 2014.
  1. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    #1 minsanity, Aug 2, 2014
  2. minsanity
    Sep 11, 2009
    581
    352
    Hmmmmm, none of the 02 guys on here has done this yet? I've so much faith in MA, I dint even bother asking anywhere else & don't plan to. :)
    Anyone got pics of the boot cable routing? That'll surely help. Thanks, guys....
  3. Canusrufis
    Canusrufis RMW Powered R53
    210
    107
    Winston Salem NC
  4. minsanity
    Sep 11, 2009
    581
    352
    Very helpful indeed!!!!!!!
    Thanks so much, Canusrufis!!!!!
  5. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
  6. minsanity
    Sep 11, 2009
    581
    352
    Thanks, Rawhyde. Either my phone is taking too long or can't open that link. Hmmm.
    Now, I'm just praying that my boot latch is the one that can take that cable. This will be tackled the next time I'm bored.:)
    This is another proof M/A always comes thru!!!! Thanks, guys!
  7. Rawhyde
    Apr 7, 2012
    311
    233
    Facilities Engineer
    It's a 500 MB zip file, so you may want to give it a whirl on a computer instead of a mobile device. There are 89 pdf files inside. It's really good info to have.
  8. minsanity
    Sep 11, 2009
    581
    352
    Thanks, Rawhyde. That's what I was guessing.:)
    I'll do that when I get home.
  9. minsanity
    Sep 11, 2009
    581
    352
    #9 minsanity, Aug 22, 2014
    Had some downtime to dig into installing the bowden cable......til I saw my 5/02 build latch was the old 1 that won't take the cable(funny, I had the holder for the pull under my rear seat):
    The updated part should have a slot for the cable head like this:
    Saw mine had just a hook for manual opening, so tried tying some fishing line there:
    Routed the fishing line thru the right side compartment up the rear RH seat belt hole. The thought here was to be able to access the manual boot release w/o removing the rear seat but still kept stealth.
    Tied & secured the line to the rear RH seat latch w/ the rubber cover removed:
    w/ rubber latch cover on:
    All buttoned up....Not OE, but I won't have to remove my seat in case I need to manually open the boot!
    Works like a charm. Hope this can be useful for those who share my fate.:)
    Yeah, bad pics, I know. Apologies!:D
    Thanks again, Canusrufis!
  10. minsanity
    Sep 11, 2009
    581
    352
    Had I dug in prior to getting that useless bowden cable, this would've been such a hobo mod.:D
    So, here's a very easy 1, 02 guys.:)
