Engine Drivetrain 1st Gen Cooper S 03 Clutch Replacement Issues
Discussion in 'Tuning and Performance' started by xsmini, Apr 16, 2016.
  1. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
    I'm looking for a little help. I just finished rebuilding my 03 s with just a little over 365,000 miles. Good news, got it all back together and it fired right up. Since I had the engine out I decided to replace the original clutch, pressure plate, dual mass flywheel, throw out bearing, and guide. Now the part I can't figure out. The throw out bearing comes into contact with the pressure plate splines after about a 1/2" of travel, thus the slave cylinder does not have enough travel to fully release the clutch. I dropped the engine again figuring I had missed something, I cannot find anything not put together correctly. Any suggestions would be appreciated. Thanks,
    Nik
  2. BlimeyCabrio
    Pics might help
  3. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
    Photos to explained
    Shifter arm where throw out bearing should be in contact w/ pressure plate splines
    Shifter arm where throw out bearing comes in contact w/ pressure plate splines...
  4. BlimeyCabrio
    That part I understand. I meant pics of the interior of clutch / guide tube / throwout bearing / flywheel / etc. would probably be helpful to diagnose.
  5. BlimeyCabrio
    Just checking... which side of the slave cylinder mount are you installing the slave on... If you install the slave wrong, it will have this same symptom...
  6. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
    I'll get pics of the inside tonight. I didn't snap any when it was apart last time. The slave is installed correctly. I did think of that :)
    Nik
  7. MCS02
    Do you have the throw out bearing installed in the correct direction.
  8. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
    Haha, yes, yes I do
  9. MCS02
    Sorry I had to ask. Believe it or not I have seen it done on a different brand car.
  10. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
    No worries, glad you did.
  11. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
    Still haven't figured out the clutch issue. Here are some photos of the inside.
    Flywheel, clutch and pressure plate all put together.
    Point where throw out bearing should come in contact with pressure plate
    Point where throw out bearing actually comes in contact with pressure plate
  12. jasonsmf
    jasonsmf Active Member
    111
    27
    engineer
    Elyria, Ohio
    Have you double checked the bolt that attaches the yoke to the shaft? If that's sheared off internally, it might cause this problem.
