Engine Drivetrain 1st Gen Cooper S 03 S falls on its face
Discussion in 'Tuning and Performance' started by S curvz, Mar 17, 2012.
  1. S curvz
    S curvz Member
    Oct 31, 2010
    178
    16
    This morning I took the MINI out for a club meeting, to get a new shifter ball, and just all around fun. All was well until I got off at my exit. Around 2k RPM, it felt like the traction control over ride kicked in. Put it in neutral, coasted, then back in gear and all was well. The next two stop light starts I took off and took the rpms up and had no issue. Pulled off on a side street, and put the car in second and started to accelerate. Around 2500 rpm it happens again. Once the engine got back down under 2k, it went again, not pausing again.
    Once in the garage, I scanned with my scan gauge and found no codes. No lights, no nothing. Any ideas?
    Thanks
    Sean
  2. miniconcarne
    miniconcarne New Member
    38
    Machinist
    Home
    Check your IC boots, mine did something similar. My boots were worn out and not sealing, funny thing was it seemed only to act up during lower RPM/boost. Just a suggestion, good luck.
    Maybe the new shift knob is too heavy or something. Or could it be you went to some club. We at the un-club were glad to see you this morning.
    When you narrow this down let us know what it was. I have no clue on this one. miniconcarne may be onto something.
  4. S curvz
    S curvz Member
    Oct 31, 2010
    178
    16
    The knob is great, as is the unclub.
    I will take a look at it tomorrow. That part did have to come off before we could put on the new bypass. If that doesn't work, maybe north end wrench?
  5. cooper99
    cooper99 Member
    Oct 21, 2010
    Circus side show
    I'm not sure either Sean, but I'd recommend calling Chad at DT and see what he has to say before you bring it to any local shop. If it's just replacing the intercooler boots or something simple, you can probably do it yourself.
    My guess though: it has something to do with a sticking bypass valve.
  6. jiminni
    jiminni Well-Known Member
    262
    Ca.
    +1 Once it gets boost you could be developing a leak. Do you have a boost gauge? Also, can you creep up beyond 2k slowly, another words, not under boost?
  7. S curvz
    S curvz Member
    Oct 31, 2010
    178
    16
    I sod not have a boost gauge and I am not sure I can creep up?
  8. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    Wouldn't he have a code if he were losing boost that drastically? My DSC has been acting up lately similar to how the OP's is. Does the light for your DSC blink when your car is doing this? Another thing you can try is turn off the DSC and see if the problem is still there. you may have a overly sensitive speed sensor or one that is failing but not quite ready to get you the xmas tree lights.
  9. jiminni
    262
    Ca.
    Not sure if it will throw a code? Good question. And I assumed he would have already turned off the DSC? Good question also. That's why I have the FES modual......no pesky DSC for me :)
  10. S curvz
    S curvz Member
    Oct 31, 2010
    178
    16
    I didn't see any lights going off and did not think to test the issue with it off. I was shocked I was able to duplicate the issue.
  11. BThayer23
    Could be a failed crank pulley, too.
  12. agranger
    1,486
    When my IC boots were leaking just slightly I got a code and a SES light.
  13. agranger
    1,486
    That's an interesting thought... if it is ALMOST done, but still grabbing at lower RPMs, this could be it.
  14. BThayer23
    Mine worked fine until I pushed the car into positive boost pressure (around 2500 rpm), then it threw a bunch of lights and went into limp mode.
  15. S curvz
    S curvz Member
    Oct 31, 2010
    178
    16
    This sounds expensive....
  16. S curvz
    S curvz Member
    Oct 31, 2010
    178
    16
    Finally had a chance to pop the hood. It appears the the driver side intercooler boot was not tightened down on the outside. I'm no mechanic, but I think that might have caused a boost leak. Test drive tomorrow.
  17. agranger
    1,486
  18. S curvz
    S curvz Member
    Oct 31, 2010
    178
    16
    Haha, easy. You have more faith than maybe you should, I couldn't even remember to tighten the intercooler hose.
    I'll look at your right up.
  19. jiminni
    262
    Ca.
    Or.........around $150 for parts :Thumbsup: Ask me how :biggrin5:
  20. ZippyNH
    #20 ZippyNH, Mar 20, 2012
    Look closesly at your crank pulley...
    My mechanic showed me if you take a prybar and can wiggle the pully eassily when the car is jacked up/on a lift, the oem one is on borrowed time....you can look at the edges of the rubber i guess, but i guessing the rubber changes over time from heat/etc and lets go...
    Kinda waiting till warm weather and getting the $$ to do mine...trying to decide if the extra $$ on the ati is woth it compared to the gel/liquid one (the ati is actually mercury filled, but safe if i remember right).(edit-ati i have been told is not mercury filled by a member, but also an elastomer of some type)
