1st Gen R53 Cooper S 06 MCS starting problem.
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Mini813, Sep 3, 2013.
  1. Mini813
    Mini813 New Member
    Dec 5, 2012
    27
    16
    Warehouse Manager
    Tampa FL
    Hi all, has been almost two weeks that my mini doesn't start. It crank but doesn't start just when she wants. I check the battery and is good. Change the spark plugs and still didn't start. I check to see if I have power on the I plug that goes in the coil pack and was only 2v. I change the coil pack and nothing. Then 3 days ago its start. When to work and before going to the dealer didn't start again. What can that be? There's low volts going to the coil pack. I don't know what else to try.
  2. Mini813
    Mini813 New Member
    Dec 5, 2012
    27
    16
    Warehouse Manager
    Tampa FL
    I forgot to mention that I have the code P1692.
    Check the crank pulley, make sure it has not cracked and separated.
  4. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Could be your fuel pump. However, when my fuel pump went, there were no engine codes thrown.
    Fuel pumps typically last around 10 years give or take 2 or 3.
    Also take the opportunity to change your fuel filter.
  5. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    Assuming it's a manual transmission could it be the sensor for the clutch pedal that perhaps doesn't think that the pedal is pushed in all the way?
  6. Mini813
    Mini813 New Member
    Dec 5, 2012
    27
    16
    Warehouse Manager
    Tampa FL
    Well got my little rocket fixed. The dealer replace the fuse box cuz was no power from the box to the fuel pump .
  7. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    Grats for hunting it down & thanks for sharing!
