1st Gen R53 Cooper S '06 Mini S Front Suspension
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by matchframe, May 16, 2016.
  1. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Video Tech for Boeing at NASA Houston
    Dickinson, Texas
    My son has a 2006 Mini Cooper S. Last night he hit a curb pretty hard on the driver's side front wheel. He was able to make it back home and after I drove it down the street, I came to the conclusion that he was lucky to drive it home. I pulled the wheel today but since it is raining, I can't dive into finding out exactly what is damaged. The only obvious thing I saw was part of the sway bar linkage was rubbing on the driver's side drive shaft. I am posting a picture of that. Other than that, I really can't see right off what is damaged or broken. Any ideas?
  2. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    Looking through the Bentley Service manual and two other manuals, I have almost come to the conclusion that the ball joint that holds the lower arm to the frame may be broken. That would explain why the wheel and drive shaft have moved back to where it rubs against the sway bar link.
    Does that sound like a possibility?
  3. Red Bull
    Red Bull Active Member
    Aug 9, 2014
    524
    207
    Check the lower control arm bushings. If that's it behind the sway bar end link in the picture, it looks like it might be worn out. Also, check the strut mount for damage and mushrooming.
  4. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    The rain stopped long enough for me to get a closer look. What I found it the lower control arm is bent back. With the geometry changed, that put the sway bar link rubbing on the drive shaft.
    You can see how the arm is disfigured at the bend. I estimate the arm at the wheel side is moved back at least 1/2 an inch.
  5. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    The bushing looked ok. I will go check the strut mount. Where you are talking about is where the top of the strut mounts?
  6. BlimeyCabrio
    Lower control arm bending is a common failure mode on these cars when you whack the wheel hard like that. That's probably your primary issue, and may be the only real issue. Also possible the bushing at the rear of the arm is damaged or worn out, as others have said. Also possible to bend the upper strut mounting plate and the strut tower itself.
  7. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    Ok, thanks! When I order the control arm, I will get a new bushing for it as well. Next time I am checking out the car, I will look at the strut mount and tower for damage.
    Thanks!
  8. Red Bull
    Aug 9, 2014
    524
    207
    Check out the description and black and white picture/diagram of the strut mount protection plates
    http://new.minimania.com/part/NMS7300/Mini-Cooper-Suspension-Strut-Tower-Reinforcement-Plates
    If the towers are mushroomed, so are the strut mount plates, along with possible broken rubber bushings. The strut towers are weak and hard hits cause this issue. There are other types of plates available to prevent this, some mount underneath between the mount and tower, and others are like the ones in the link, but can also mount an optional strut tower bar to connect the two towers.
  9. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
    Consider getting Powerflex control arm bushings. You'll get much longer life, crisper handling, and no additional noise or vibration. Since you took such a hard hit, it might be a good idea to install a fresh set of ball joints while you're in there.
  10. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    That is a great idea for strengthening the strut tower! Definitely have to get a set of these!
  11. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    Good idea! Thanks!!
  12. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    Looks like the strut tower is mushroomed. Definitely going to order a set of strut mount plates.
  13. Red Bull
    Aug 9, 2014
    524
    207
    WOW!! :eek: ... that's the worst case of mushrooming I have ever seen :crazy:
  14. MCS02
    6,328
    That is very bad! Time to get a block of wood and a BIG hammer!! Defiantly get the PowerFlex bushings, the stock ones don't last long.
  15. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    I think that I may have a used, but good, control arm. Get the part number off yours, and PM me. I will take a look in my garage when I get off work tonight. If I still have it, you can have it for the price of shipping.
    Ray.
  16. M1N1
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Control arm. Off to work now.
  17. Rawhyde
    Apr 7, 2012
    311
    233
    Facilities Engineer
    This kind of thing is why MA is the best MINI forum on the web. I hope karma pays you back tenfold for this act of valor!
  18. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    That is so cool! Thanks!
    PM sent
    Bill
  19. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    Update; I received the Control Arm Ray sent me. Thanks so much! I will be ordering all the other parts I need to get the Mini back on the road today.
    When my son hit the curb that did the damage to the control arm, the driver's side wheel was also damaged so I looked through Craigslist for another wheel. I ended up buying a set from a local guy for $200. I did not need all 4 wheels but I could not pass up the deal. Now I have backup wheels if he damages another one.
  20. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    All of my parts has arrived. Look what showed up yesterday!
    Hoping the weather stays good this weekend to finish up all the work. It will be good to have the Mini back on the road.
