2nd Gen R56 Cooper S '09 S wont start
Discussion in '2nd Generation: 2007+ R55 through R61' started by fallentrance, Aug 20, 2015.
  1. fallentrance
    fallentrance New Member
    Aug 20, 2015
    #1 fallentrance, Aug 20, 2015
    Okay, Ill try to nutshell much as possible.
    I bought a '09, for a ridiculous 3200$, 88,000Miles, no rust. Might sound cheesy, but anyway. When i hit the ignition, it cranks, backfires, But doesn't start. For sure there is compression. Any idea's? I'll be doing the repairs myself. I always work on my own vehicles :Thumbsup:
    Cheers.
    I'm no help with your engine/starting issue but I can fix this. :Thumbsup:
  3. Zapski
    I have no ideas for you, but Welcome to the site.
    Here's a free bump.
  4. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Timing chain slipped will be my first thought.
  5. fallentrance
    Aug 20, 2015
    Thanks, ill look into that!
    Thanks for the welcome!
    Thanks :Thumbsup:
  6. Metalman
    Would the jumping of one gear tooth cause the valves to hit the pistons?
  7. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    The first thing I would do is remove the valve cover and check the timing chain guides for cracks and damage, then I would look to see if the flat spots (located on the end of the cams near the HPFP and vacuum pump) on the exhaust and intake cam are properly aligned. You should be able to see with the naked eye if there off by more than a few teeth which would seem likely if your timing chain if off enough to cause starting problems, if it's difficult to tell then you might not be off by to much. If your not off by much your pistons and valves might be alright. Torque specs for the valve cover is 10Nm or 7.3 ft-lbs.
  8. MCS02
    6,317
    Welcome to MA!
    What they said
  9. 00Mini
    2,263
    Welcome to Motoring Alliance !! It looks like your getting some pretty sound advice to your question. Good luck with your repairs.
  10. fallentrance
    Aug 20, 2015
    Thank you very much!
  11. Systemlord
    Mar 28, 2013
    311
    67
    You are welcome, if you need pictures of the cams flat spots I can provides picture and YouTube videos showing you where that are located when I get home from work tonight. If you are off by a couple of teeth I would recommend getting ahold of a bore scope and looking into the cylinders to see if the valves struck the pistons, if they did you will see these half moon shaped marks either on the intake valve side of the piston or the exhaust side. If there minor marks they might need to be filed or polished out because they might create hotspots while driving causing pri-ignition. We I mean I'm getting a little ahead of myself so let's see what the timing chain, guides and cams have to say about it before we go too much into that.
  12. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    First, scan the car for stored error codes. Then, check the timing chain guides. If they're bad, you should change the whole timing set as opposed to replacing parts a la carte.
  13. fallentrance
    Aug 20, 2015
    Thanks guys, i dont think ill need pictures, but its good knowing in advance. But before i get to the Cooper S, i need to fix the powersteering on my R50 Cooper. Powersteering is like gone on it. If i recall there was a recall for the powersteering. Oh Boy. After i fix that ill jump to the Cooper S!
    And here is what the Cooper S looks like.
  14. fallentrance
    Aug 20, 2015
    Update? It's finally running after 5 years, to everyone who chimed in much appreciation.
    The Culprit?
    The timing chain tensioner literally just snapped which is common, which led to the exhaust side valves all to bend. I was able to salvage the head and get it repaired (phew), all new valves, etc. Here is a picture of the exhaust side valve, that shouldn't look like that ha!
    Here is a couple rev's. Whats left? Put the front end back together, figure out why my rear brake lines are leaking, and get an alignment and should be all set to go back on the road!
  15. 00Mini
    2,263
    Glad you were able to get the problem corrected and your original exhaust valves will make interesting conversation pieces.
  16. MCS02
    6,317
    Wow glad you got it back on the road
