12V Compressor
Discussion in 'MINI' started by TPLS BLR, Nov 21, 2010.
  1. TPLS BLR
    TPLS BLR Member
    Dec 1, 2009
    81
    Finance
    San Pedro
    Not sure if this is the right place to start this thread, but, I want to get a 12V air compressor to top off my tires at the track. I have seen some guys using the cigarette lighter ones, but it can take a long time just to get a few lbs of pressure, and they don't last long, heat up to quick. I am looking at a couple from Super Flow, and the two I like are 30A & 40A. You need to have the car running to use them, and I do not see that other functions, i.e. stereo, heated seats and such will be on at the same time. So, what can I run?
    Thanks,
    Tom
  2. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    When I swapped out the run flats for real tires I got the MINI/BMW Mobility kit (tire goop and compressor)
    I just got new tires and apparently they didn't quite seal the bead on the rim so I was met with 0 psi in my right rear at 5P earlier this week
    That compressor running off the 12V cigarette lighter filled that tire to 35psi in no time :Thumbsup:
  3. goaljnky
    3,105
    394
    I just picked one up from Harbor Freight:
    12 Volt, 100 PSI High Volume Air Compressor
    Pretty quiet, doesn't get too hot and is fairly quick. But, I have also found that a $12 manual foot pump I got from Big 5 is just about as fast.
  4. RonsMinnie
    RonsMinnie New Member
    449
    Sugar Land, TX
    I would go cordless, much more convenient for track use, I am starting to see a lot of these at the track. Fifty bucks will get you a pretty good one.
  5. goaljnky
    3,105
    394
    Link?
  6. minimark
    I just use the 12v compressor in my slime kit.... Its slow and noicey as hell but it gets the job done and I carry it in the car anyway....
  7. RonsMinnie
    449
    Sugar Land, TX
    [ame="http://www.amazon.com/Schumacher-IP-95C-Jump-Starter-Compressor/dp/B0012MYI8U/ref=sr_1_20?s=automotive&ie=UTF8&qid=1290436960&sr=1-20"]Amazon.com: Schumacher IP-95C Jump Starter & Air Compressor: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41FpaB7QkDL.@@AMEPARAM@@41FpaB7QkDL[/ame]
    This one is at Sam's for 49.99
    [ame="http://www.amazon.com/Stanley-J5C09-Jump-Starter-Compressor/dp/B002X6VXL4"]Amazon.com: Stanley J5C09 500 Amp Jump Starter with Compressor: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/51bLiPz-4dL.@@AMEPARAM@@51bLiPz-4dL[/ame]
  8. YesIFit
    YesIFit New Member
    May 25, 2009
    231
    I've had this one for over a year and it's served me well. I picked it out b/c our flatbed trailer requires 60 PSI and our 2500HD requires 80. Plus, the LED light is nice for adding air early in the morning. Here's an Amazon listing, but I got mine from Northern Tool.
    [ame="http://www.amazon.com/Goodyear-i7000-12-Volt-Heavy-Duty-Inflator/dp/B001D5HP40"]Amazon.com: Goodyear i7000 12-Volt Direct Drive Heavy-Duty Tire Inflator: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/217MhQ1mPwL.@@AMEPARAM@@217MhQ1mPwL[/ame]
  9. ScottinBend
    Another alternative I use and see folks using is the small air tank. Easy to fill before leaving the house and easy to get refilled at the track if needed from a fellow that has a trailer and a big compressor.....lol
    [ame="http://www.amazon.com/Portable-Air-Tank-5-Gallon/dp/B000FNA700"]Amazon.com: Portable Air Tank (5 Gallon): Home Improvement@@AMEPARAM@@http://ecx.images-amazon.com/images/I/21vQkSDVi6L.@@AMEPARAM@@21vQkSDVi6L[/ame]
  10. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I have an airman that fits inside the side cubby hole in my boot. That's for emergencies.
    However, when I need to pump a lot of air into my tire fairly quickly, I use a manual pump and get some exercise doing it too. If it's to the track, I would throw this in the boot and us it instead of an electric one.
  11. goaljnky
    3,105
    394
    I have something like this:
    Bought it for my bicycles, since I like my tire pressure to be about 60 psi, and the 12v I had was not getting it there. Found that it works pretty well and pretty quickly on car tires as well.
