Engine Drivetrain 1st Gen Cooper S 15% vs 17% Pulley
Discussion in 'Tuning and Performance' started by goaljnky, Jul 30, 2009.
  1. goaljnky
    3,105
    394
    OK, so the car's been out of the body shop for almost 3 weeks now. And all of a sudden I have an itch. So, should I drop a 17% pulley into my factory JCW with RMW tune? Will I need to have Jan re-tune it?
    Those running the 17: any long term negative effects?
  2. goaljnky
    3,105
    394
    P.S. What size is the stock JCW pulley?
  3. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    I went with a 15% on my JCW. The JCW pulley I took off measured to be 11.45%. To maximize any gains a re-tune is recommended, and more important the further you more away from the stock pulley.
    Most consider the 15 to be more for track and the 17 more for street, so the use of the car is a factor to consider.
  4. ScottinBend
    The 17 will generate more heat thus the reason the 15 is most widely suggested.
  5. cct1
    17 will give you help down low, but up high it'll spin faster than supercharger can handle, just generating a bunch of heat, but no improvement in power at higher RPMs. You're a track rat right? I'd stay with 15, it still helps down low, and is pretty much is the upper limit of what the supercharger can usefully handle at high RPM's. And it's not like there's going to be a huge difference in performance even down low going from 15 to 17, I don't think that small of a change is really going to be worth it, just my 2 cents.
    I have the JCW, and eventually (when I'm having some other stuff done) probably swap out to a fifteen. Don't know why they didn't go with a fifteen in the first place....
  6. Nathan
    JCW didn't come with a 15 as at redline thats out of the S/C range and being OEM and all....
  7. cct1
    Really? Even 15% is out of the S/C range at redline? Didn't know that, I thought 15 was the upper limits. Learn something new every day! Maybe I'll just stick with my JCW.
    The other thing is belts--seems folks go through belts fairly quickly with the 17's.
  8. Bimmer Lite
    Bimmer Lite New Member
    English/Journalism teacher and writer
    NJ
    Internet hearsay tells me the JCW pulley is an 10-12% reduction depending on which site you remember reading.
    - Marc
  9. goaljnky
    3,105
    394
  10. mini_racer
    Engr Manager
    Not true for the pulley I took off my 2006 JCW car. See post #3.
  11. cct1
    Yeah, everything I've read is the JCW pulley is just under 12 percent. There is a picture floating around somewhere of a JCW pulley side by side to a 15% pulley--the difference is definitely noticeable.
  12. mini_racer
    Engr Manager
    For my car, the 15% delivered 1.5psi of boost over the JCW pulley. While not huge, it still was significant and it made a real difference.
  13. goaljnky
    3,105
    394
    You are right. Some more searching is confirming what you've already said. I guess I know what I will be doing on Saturday. I figure going from 11.5 to 15 should be close enough for me to stick with the tune I have. Jan already had 218 squeezed out of it. Maybe the 15% will give me another 3-4 hp.
  14. goaljnky
    3,105
    394
    Perfect. What was your boost before and after?
  15. mini_racer
    Engr Manager
    Before = 13.5 psi
    After = 15.0 psi
    I believe the 14 -to- 16 psi range is about normal for a 15% pulley and stock cam, head, headers. A high flow head especially, can lower the boost pressure a little.
  16. goaljnky
    3,105
    394
    Sounds about right. Mine blows about 13.5 right now.
  17. Batrugger
    Batrugger New Member
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    Go with the 15% Jerry, or you could get one of those 16% ones and try to get Danny to install it :p. 15% will be perfect for what you do with the car.
  18. mini_racer
    Engr Manager
    So what are you waiting for? Get a decent 15% pulley, I like the Al ones with as many clamping machine screws as possible, three is too few for my taste, four is fine, mine has six. They are plenty cheaper than they used to be. Even for a JCW car, this is one of the best perf mods you can do. Street driveability increased significantly. Also, get the Napa/Gates 060535 belt, regardless of what Alta or some of the other vendors reccommend.......get the 060535 belt. It is a snug fit to get it on, but it will NOT slip.
  19. Batrugger
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    No need to worry, I'm sure he will be going to MINICORSA so he will be in great hands :cornut:
  20. goaljnky
    3,105
    394
    I am going to try to find a Webb pulley. The original. :D Or maybe some of the OnWhoreizon offerings. I have a feeling that getting Danny to install a 16% would require a lot of lube. And not in a good way.
