1961 Mini .vs. 2011 Mini
Discussion in 'MINI' started by Angib, Dec 19, 2011.
  1. Angib
    Which?, the British consumer magazine, has celebrated the 50th anniversary of its motoring section by testing a 1961 Mini against a 2001 One D - this is a base model low-power diesel sold in Yurp.
    Clips of the article are attached, but some high points are:
    - even the One D has more than 2.5 times the original's 34hp;
    - the One D weighs exactly 2.5 times as much as the original;
    - the One D is quicker than the original through a slalom test, but not by a huge amount. (48 .vs. 40mph)
    It seems shameful that the One D on 17" modern radials is only 20% quicker than the original on cross-plies, but then it is also 20% wider than the original.
    I guess the fact the 61 Mini doing so well against the modern One D goes to show what a giant killer the original was back in the days when it was new. They talked a bit about safety, but that is where there's huge advantage for the new MINI.
    That was an interesting read, thanks for posting it up. :)
