1st Gen 1st gen cabrio vibration issue
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by TOPLESSMINI, Aug 6, 2018.
  1. TOPLESSMINI
    TOPLESSMINI Member
    Sep 1, 2015
    31
    11
    Software Consultant and Training Specialist
    Kingston, ON
    Hi everyone,
    I am trying to fix a vibration that comes up around 100 km/h on my 05 Cooper S Cabrio. I bought new tires and rims about 2 years ago and started noticing the vibration last year. Had the tires rotated and balanced this spring and was told 3 of the tires were out of balance so got that fixed but the vibration is still there (happened around 120 km/h before, now 100). Had the tires rebalanced at another garage and they found one tire was still slightly off so they took care of it but the vibration is still there.
    It's weird because the vibration level can change a lot from day to day. Sometimes you hardly feel it but most often it's really noticeable. On the odd day it's so bad you'll see the rear view mirror shake and you feel it in the whole car.
    I've been told this could be caused by flat spots on the tires (it's my second car and only driven in the summer).
    I would really like to get rid of this shaking as I love the car and plan to keep it for the foreseeable future but it's annoying not knowing what's causing it. I installed a couple of strut tower reinforcement plates this spring and plan to add a strut tower bar next year.
    Anyone out there have some suggestions?
    6,316
    A slight possibility its your lower control bushings. These usually go bad around 40k. If you kick the front of your front wheel and it moves any its time to replace them. Use PowerFlex bushings they will be good for a long time.
    When the shops pulled your wheels did they clean all the rust off the back of the rim and the brake rotor there the two mate? If not that could be it.
  3. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    Look for a tire shop w/ Hunter Road Force Balancer. Try that 1st.
    Sent from my SM-G950F using Tapatalk
  4. TOPLESSMINI
    TOPLESSMINI Member
    Sep 1, 2015
    31
    11
    Kingston, ON
    Thanks for the tip. I will check the bushings. I don't know if they cleaned the rust off the back of the rim however last time I removed a wheel I didn't notice any rust, at least nothing that required cleaning (to my untrained eye anyways). Might take the wheels off and check though...
  5. wmwny
    4,040
    2,242
    Could you check the alignment?
  6. TOPLESSMINI
    TOPLESSMINI Member
    Sep 1, 2015
    31
    11
    Kingston, ON
    Just to follow up on my last message. Alignment was fine, as was wheel balancing. A local mechanic found a worn out ball joint on the passenger side. Got it fixed and now the vibration is practically gone. It's much better than before but not 100% perfect. It's an older car so I'm not expecting perfection at this point.
    Now moving on to other annoying issues...
  7. MCS02
    6,316
    Mini, annoying issues........?
  8. TOPLESSMINI
    TOPLESSMINI Member
    Sep 1, 2015
    31
    11
    Kingston, ON
    LOL!!!
    Yeah... Right...
    Just because something is old doesn't mean it has to have annoying issues even small ones. I'm old & ask my wife if I have any. On second thought don't..... o_O
