Engine Drivetrain 1st Gen Cooper 2007 mimi
Discussion in 'Tuning and Performance' started by Mitchgray, Apr 26, 2017.
  1. Mitchgray
    Mitchgray New Member
    Apr 26, 2017
    How do I tell if my mini has IBS. And if it doesn't do I still have to reprogram the ecu. Someone replaced the battery before I bought the car and it will not start now.
    It will start if pushed. Thanks mitchgray
  2. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    This problem doesn't sound related to the IBS.
    However the IBS is a plastic box maybe the size of a pack of cigarettes and is in-line on one of the battery cables maybe 6 inches or so from the battery post connection.
    The purpose of registering it with the system is so that the car knows it is a new battery and it doesn't need to be charged as aggressively as an old battery.
  3. MCS02
    Also Mini can act funny when a battery is going bad. Have a load test done on the battery. Also check all your connections and grounds and make sure clean and tight.
    How old is the battery?
