Engine Drivetrain 2nd Gen S 2nd Gen S Maintenance
Discussion in 'Tuning and Performance' started by Metalman, Feb 3, 2017.
  1. Metalman
    Thanks. Now that my Wife has a gen2 I need all the help I can get.
  3. 00Mini
    2,227
    Some real good points of interest those who own or maintain a second generation S.
  4. Zapski
    Lot of good info in there.
  5. Tigger2011
    Tigger2011 Member
    Oct 30, 2013
    38
    25
    Fort Lauderdale, FL
    Yep good info there. Etuners even went so far on a build as to key the crank where the lower timing sprocket sits. Definitely a permanent solution. Still boggles my mind that friction is the only thing holding that sprocket in place. Not sure what BMW was thinking by letting that slide through engineering.
  6. Metalman
    Well...
    They aren't the only ones that do that kind of stuff...
    Just last week a fellow stopped in with a 5th gear out of a manual transmission. The gear was a 2 piece friction fit assembly out of a Datsun 2000.
    Made a slight mod so the two pieces act as one.... Fixed...:Thumbsup:
    Purdy welds.... :)
