2nd Gen R56 Cooper S R56 Oil Change
Discussion in '2nd Generation: 2007+ R55 through R61' started by TGS91, Jun 1, 2010.
  1. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Changed the oil over the weekend and I've been following the method outlined in the Library section
    http://www.motoringalliance.com/library/2nd-generation-mini-cooper-how-to-4/r56-oil-service-13/
    Problem I've been having is that other than the first time I changed the oil on the R56 I get a nice little pool of oil from the filter when I remove it.
    As I mentioned I've followed the directions of backing off the seal on the gasket, raise the car and set jack stand from drivers side at the angle represented, let the oil drain 15+ minutes.
    Sure enough, oil puddle
    Reading the article again it seems the only variance is that I have not lowered the car prior to putting the new filter in. This seems counterintuitive
    Whats your experience?
  2. Rally
    Rally New Member
    50
    Ohio
    I had a puddle there as well.
  3. Metalman
    No puddle with my R56 oil change. I did however stuff a cotton rag under the aluminum casting of the oil filter frame (for lack of a better description), before I un-screwed the plastic filter top. I just figured with the angle and all, there might be some spillage.
  4. jcauseyfd
    jcauseyfd New Member
    May 25, 2009
    201
    31
    Graham, NC
    fwiw, I use ramps that I pull my MINI up on for oil changes. I do that first.
    Then remove the oil cap on the top of the engine. Loosen the oil filter housing just enough to break the seal. Remove oil drain plug and let things drain. Wait 15-30 minutes, then finish removing the oil filter.
    I'm not sure, but I think part of the key is taking off the oil cap. Seems like I read that somewhere. Makes sense to me when I think about a straw in a drink and how putting your finger over the top of the straw lets you pull the straw out full of fluid due to the vacuum created. Same concept with the oil change. Just breaking the seal on the filter helps stop that, but may not be sufficient to avoid the oil pool.
    Good luck!!!
  5. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    I've tried, two ramps, a single ramp, put up on a single jack stand as represented in the article above and puddle city every time
    I *think* I'm breaking the seal on the o-ring, maybe I need to backoff a couple more turns.....
  6. Minidave
    4,614
    I think you're always going to get a little oil out of the filter, no matter how you tip the car or how long you wait. I just stuff a rag under it to catch the drips - no muss, no fuss.....
  7. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    As long as were all in the same boat so be it
    Seems to be some bad design but then again I'm sure there are some engineering tradeoffs with such a small space packing the punch it does
    Thanks guys
  8. MinixB
    MinixB Member
    Jul 14, 2009
    269
    14
    Female
    Graphic Account Specialist
    Kansas City, MO
    I've got a question about oil changes. My Mini has 2800 miles left till dealer maintenence but it has been 7500 miles since my last oil change and the dealer won't change the oil until the service indicator is under 1500 miles. So...do I change the oil now or just wait until the dealer can do it?
  9. Nathan
    If it was mine I'd change it now making sure the service indicator was not reset. Depending on how you drive that 2800 miles may really be more than 2800 miles, a lot of highway driving will slow the count down. When it gets closer to the 500 mark then I'd schedule the dealership change.
    Then again if you intend on trading the car in when it hits the end of warranty then I'd not bother and wait for the service indicator.
  10. MinixB
    MinixB Member
    Jul 14, 2009
    269
    14
    Female
    Kansas City, MO
    Hmmm...okie dokie. I'd have the dealer do it tomorrow when I take him in for some other work but they charge about 150-200 dollars for an oil change...
    There has to be less expensive options in the area. Any good BMW shop should be able to do the work for a heck of a lot less. And if you are so inclined, there is a detailed How To in the Library by Chad of Detroit Tuned.
  12. MinixB
    MinixB Member
    Jul 14, 2009
    269
    14
    Female
    Kansas City, MO
    I'm going to get the oil and filter and see if I can get the help of MiniDave (since he's in the KC mini club :) ) But I gotta figure out a time to do it first.....
  13. cop1406
    cop1406 New Member
    Jan 6, 2010
    64
    6
    Oink Oink
    Sonora, CA
    Very easy job, took me 30 minutes. Do not pay your dealer unless you must.... Changed mine at 3000 miles and plan to do it every 5000. MINI is smoking dope when they say to let it go until their first scheduled somewhere around 15000-20000.
  14. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
  15. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    PS - You will likely get a oil spill from changing out the filter. Only way I've found to avoid is to let it drain for like 20 min. Other option is to get a second oil pan
  16. Minidave
    4,614
    I stuff a shop rag under the filter housing before I take it loose, catches everything just fine - no muss-no fuss.
  17. jwreck
    jwreck New Member
    Jan 11, 2011
    6
    Glad to see I'm not the only one who LOL'ed at the salesman when he said it didn't need an oil change for 15k miles.
  18. Jason Montague
    :frown2:Yeah happened to me too. I quietly said," well you're under threat of firing other wise sooooo........How much to CHANGE THE FRIGGIN OIL AND FILTER:mad5:?" $70 @ MOD ,Sir. Lets do it:cornut:."
  19. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    How about a topside change. Looks seriously easier:
    [ame=http://www.youtube.com/watch?v=5TCUdiHDnUg]YouTube - 2008 R56 MINI Cooper S Oil and Filter Change[/ame]
    This product I believe is around $40 http://www.liquivac.com/
  20. mini on
    mini on New Member
    Jun 11, 2009
    20
    That topside oil changer is 49.99 @Amazon/Northern Tool. Go to airpower america where it's 45.99 and a refurbished one is 30.00
