2nd Gen R56 Cooper S 82mm cam chain tensioner
Discussion in '2nd Generation: 2007+ R55 through R61' started by fngolfer, Aug 20, 2015.
  1. fngolfer
    fngolfer Active Member
    Apr 1, 2012
    100
    46
    Los Angeles
    Had my cam chain tensioner replaced June 2013 with the 78mm unit. now I noticed there is yet another updated version that is 82mm in length. If my car DOESN'T make that cold start rattle, should I still replace it with the new version? 2009 R56S 65,000 miles
  2. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    if its not rattling, leave it alone.
  3. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    I had my timing chain components replaced on June 28th 2013 (51,000 miles), after almost 2 years my tensioner didn't act up ever during a cold start, but after a 30 mile drive on the freeway the moment I came to a stop off the freeway I heard a very slight chain sound.
    I replaced it immediately with the final redesigned 5th gen tensioner which I compared with a new 4th gen tensioner, what a huge smoother difference in the plunger action! While I was at it I had the timing chain measured and all was good. To each his own, but I would always install a better manufactured part in my Mini if there were known issues with the current gen tensioner that was still in my Mini.
    Paid $150 to have the new 5th gen 82mm long tensioner installed, the sound vanished and hasn't returned.
  4. fngolfer
    Apr 1, 2012
    100
    46
    Los Angeles
    Need a tie breaker now.
  5. MCS02
    6,317
    If it ain't broke don't fix it!
  6. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    I installed the new 82mm tensioner last fall and it has been quiet since. very happy with the change. My old plunger didn't have much tension left and it was the last updated model!
