2nd Gen R56 Cooper S A Month of No Usage!
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Jul 31, 2016.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    What are the specific actions i should do to the mini so it would be in good shape when i leave it without using it for a month?
  2. 00Mini
    2,227
    Possibly a battery tender.
  3. genik
    genik Member
    Feb 20, 2012
    402
    19
    What does a battery tender do?
    What if i disconnected the battery?
  4. DneprDave
    I wouldn't do anything. My MINI sits for weeks at a time without being driven with no problems.
    If I were going to leave it for a few months, I would put a battery tender on it and put it on jack stands to keep the tires from getting flat spots.
    A battery tender or float charger, is a little battery charger that puts out less than an ampere of current, it maintains the battery's charge if it is not used for a long time. It is only to be used on a fully charged battery.
    It probably wouldn't be a good idea to disconnect the battery for a month, the electronics on board need a little electricity to remember things.
    For one month, no, I wouldn't do a thing.
  5. Dave.0
    Park it and walk away, that's all you need to do for a month.
  6. genik
    genik Member
    Feb 20, 2012
    402
    19
    I havent changed battery since purchase, that was 03.2008 and have done over 100.000 km
  7. ZippyNH
    When not in use, the battery discharges a tiny bit every day...
    Things like the computer, keyless entry, etc use a bit of power in standby.
    A month should be ok...but if you do it regularly, get a battery tender.
  8. Firebro17
    I'd just cover it and leave it... Or, if no cover, just dust it off before you leave. That way you won't have that extra month's worth, on top of what you already have, when you get back.
  9. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    As said previously, a month is nothing to worry about, just park it and go. My car sits all winter, 5-6 months, and all I do is dump a can of seafoam and fill the tank before putting it into storage.
  10. Firebro17
    Oh no Dude..! Your suggestion of dumping Seafoam will take us at least four pages to straighten out the guy. :crazy:
