Brakes 1st Gen ABS/DSC code 5E14
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MCS02, Apr 2, 2019.
  1. MCS02
    6,321
    Ok I have looked High and low to find an answer. After replacing the ABS unit I have the low tire pressure light and the triangle. The ABS light is now out. This is the code I am getting.
    If you know how to fix it HELP!!!!
  2. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    Did you try to simply reset the tire pressure light (I think you just hold the button next to the parking brake for a few seconds)? The system likely needs to recalibrate after the ABS unit is replaced.
    Not sure about the meaning of the code, though. Sounds like it is waiting for you to "reset the ignition" for some CAN bus stuff to clear.
  3. MCS02
    6,321
    Yea I have tried to reset the tire pressure light. No luck. I thought maybe just driving it reset no luck there ether
