Adding a circuit...
Discussion in 'General Technical Questions and Answers' started by Goldsmithy, Dec 13, 2018.
  1. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I am going to start adding electrical accessories to my 05 R52 S MINI. Instead of adding items to the stock fuse block. I plan to tap the terminal in the engine compartment and run a 6ga wire, through a 30 amp. resettable circuit breaker, to a fuse block with 4 fuses. I will then tap into this fuse block to add accessories. I want to make this independent of the factory wiring harness. Does anyone see a problem with doing this?
    I'm not an electrical guru heck not even an electrical hack. I do know keep the + from touching the -. Otherwise the smoke that is contained in the wires will come out. Better get a jar of this stuff. :Cigar:
  3. Dave.0
    You will be fine as long as you start at the battery and go to a fuse / distribution block.
    I did this in my car when I added amps for my stereo.
  4. MCS02
    Sounds like it will work. What all are you adding?
  5. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Lee, I'm adding underhood lighting, a radar detector, a DB radio (if I can find one with all the controls in the mike), and a few other thinhgs yet to come.
  6. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    970
    732
    training specialist
    Maysville, North Carolina USA
    I have been a way a while. I am curious as to what you came up with.
  7. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Yea me to! I will see him at MOTD.. will be interested to see. :)
  8. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Hate to disappoint ya'll...but this project is not finished. After the Dragon...
  9. MCS02
    Don't rub it in!:mad::D
