Sold: A used set of adjustable Camber Plates from Ireland Engineering for R53 MINI. These plates have spherical bearings encased in urethane to offer some cushioning. You can get about 2 degrees of negative camber before factory diameter springs contact the inner fender -- perhaps a bit more if you're using lowering springs. (Note: IE's new design will allow almost 3 degrees of negative camber with narrower springs, but if you are using factory diameter springs, these will work great for you.) These plates do not fit early chassis (before 04/2002) due to the upper strut bearing being different. These were used for about 15k miles and are in very good shape. Base plates were recently repainted and most of the fasteners are new. $125 shipped to the lower 48, Paypal preferred. PM if interested. You want these if: - You are chewing up the outside edges of your front tires due to that monster swaybar you installed in the rear. - You realize you need some negative camber in the front to improve cornering grip. - You had an alignment and you found out there is more than half a degree difference in camber left to right and you need to even things out. You don't want these if: - You are already bottoming out your suspension on potholes where you live. - Your significant other already won't ride in your car because the ride is too harsh (OK, maybe that could be on the positive list as well... )
