Engine Drivetrain 1st Gen Cooper S Adventures in head porting..
Discussion in 'Tuning and Performance' started by istara, Jul 25, 2010.
  1. istara
    istara New Member
    May 21, 2009
    90
    Tucson, AZ
    Step 1:
    Actually, I think those were steps 2, 5, 8, and 10 through 13.
    Anyway, I bought a spare head a while back, intending to use it as a core to have someone else do my porting. In the meantime, money became tight and I found a friend who has done lots of porting in the past who offered to help. It seemed more logical since I have the summer off to just go ahead and port the head that's on the car, so...
    I got it off the car and we took it apart:
    First 8 springs measured at 1.7" were 73, 73, 75, 76, 76, 76, 77, 79, and 80 lbs.
    Blue'd and scribed:
    .. and start grinding
    Notice how it it almost looks like I know what I'm doing..
    Also note: tools intended for much bigger engines, for the record, are kind of hard to use. More over, tools intended for use on aluminum would also have been helpful.
    Early on from the valve side:
    Exhaust port side after a little preliminary grinding:
    Intake port side after some grinding:
    And just started sanding with 40 grit before it started to get dark:
    Disclaimer: don't try this at home. That is, unless you know what you are doing and/or you don't know what you're doing but agree not to blame me if and when something goes terribly wrong.
    More tomorrow when we finish most of it up. Still have some work on the valves to do, but hopefully everything should be back on the car by the end of the week. I will immediately regret posting this if, for some reason, something does in fact go terribly wrong. However, that's why having 2 heads is better than 1.
  2. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Would you show us a close-up of the camshaft wear you've mentioned in other threads please?
  3. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Cool to see...
    thanks for sharing and keep us posted on the progress.
    Matt
  4. Metalman
    Cool........
    A beer drinking, head porting girl.
    Great combination!:D
    Looking forward to the build.:cornut:
  5. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    :Thumbsup:
    I like her beer goggles.
  6. istara
    istara New Member
    May 21, 2009
    90
    Tucson, AZ
    #6 istara, Jul 26, 2010
    Yes, I've been meaning to get a shot of it. I'll snap one today.
      File size:
      103 KB
      20
  7. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    GREAT DYI!! The work looks good!! and you didnt try to get creative and go way past your knowledge!! ( or beer consumption!! ) Great work!!
    I didnt follow the cam wear thingy... what cam was it?? OEM?? (I ask 'cause the core looks pretty ruff) all the springs are too light ( save the 80 lb one) They will work on a stocker... but you aint there no more.
    If the cam is stock ..or the lift is under .400" you might be able to shim to correct pressures ( leaving room for coil bind) or just get a new set. I asume your friends have already advised you, cool??
    Kudos!!
    Just me..................................
    Thumper
  8. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    nice job so far
  9. istara
    istara New Member
    May 21, 2009
    90
    Tucson, AZ
    That's a newman cam. Stock one had similar wear, however:
    Just much narrower area and no pitting like on the newman.
    That's probably 25k miles on the newman and 60k on the stock cam, many of them hard miles. I should have numbers on all 32 springs by the end of the week. My measurements at home probably weren't that accurate anyway, so I'll be borrowing some tools at the machine shop.
    From there, yes, I am definitely looking at my options for springs. Probably something cheap (more stock springs, shims maybe) until I can afford to replace both the cam and springs with more exciting options.
  10. Thumper460
    May 26, 2009
    559
    94
    Cool... at the shop get the pressures and see what it will take for the pressures to get to be 85 lbs at installed height. You need to get the lift at the valve for the newman, I believe the it is close to .400 lift. Check the spring stack and see how much you can shim, and still have the coil binding distance..
    Have fun....
    Thumper
    PS thanks for the cam discription.
    Tpr
  11. istara
    istara New Member
    May 21, 2009
    90
    Tucson, AZ
  12. istara
    istara New Member
    May 21, 2009
    90
    Tucson, AZ
    Alright, car is finally up and running again. I think fixing the inner axle boot was actually harder than the whole head porting project. Wideband so far is looking good, hitting 11lbs of boost at 3500 feet altitude, 50% humidity, and 105 degrees ambient. Will take it out again tonight and see what happens, then hit the drag strip in a few weeks until I can find a dyno.
    I've been considering getting it tuned in the near future but I'm dubious about the two nearest options for that.
    But.. to the pictures! I didn't get anything too fantastic of the final ports since the light wasn't good. Just take the C&C pictures you've seen and pretend they're a lot rougher and 'handmade' looking.
    Swirl polished valves:
    Putting the head back on is easy as 1:
    And couldn't resist touching up the intake manifold and horns while in there. Didn't have quite the right tools to make them perfect (no mirror finishes here) but we did get the ports perfectly lined up. Took a little material off a gasket or two and had to do a bit to get the intake manifold ports perfect with the head including opening up the outside holes so there was more wiggle room on re-installation.
    And for bonus points, this is the one and only spare part I ended up with: :mad2:
    13mm head... any ideas!? :crazy:
  13. Onasled Racing
    Onasled Racing New Member
    Jul 19, 2010
    172
    Fuel rail
  14. beaner
    beaner New Member
    44
    Spent much time around these motors, Greg!?
  15. Mr. Jim
    I second that! Great job, thanks for sharing.
    Cheers
    Mr. Jim
  16. Onasled Racing
    Jul 19, 2010
    172
    More then I'd like. :eek:
    I probably should have said "Fuel rail ?"
  17. Eric@Helix
    1,257
    Shepherd
    Philadelphia
    Close, Greg, but not the fuel rail. It's the bolt that holds the water line bracket on the intake side of the head. The fuel rail bolts are black coated.
  18. Onasled Racing
    Jul 19, 2010
    172
    Oh....haaa. I don't have one of those anymore I guess. ;)
  19. goaljnky
    3,105
    394
    You all need to start a bolt identifying thread, cause I have about a half dozen that I have no idea where they came from.
  20. BlimeyCabrio
    I think a few fell out of your left ear.
