1st Gen R52 Cooper Convertible Air bag system light
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by davavd, Sep 14, 2017.
  1. davavd
    davavd Club Coordinator
    6
    Architect
    Covington, La
    My car (2006 Mini S convertible) has the air bag system warning light. The code reader shows a code for the explosive switch that disconnects the battery in the event of an air bag deployment. The shop I'm using says they would have to replace the whole cable (runs length of car) and that there is no guarantee that would solve the problem. They said they thought there used to be a kit to replace just the switch, but that now they can't find it. this sounds like the reason I'll sell it, but i hate to do that because otherwise, i am totally happy with it. Any thoughts?
  2. Metalman
  3. davavd
    6
    Architect
    Covington, La
    Air bag did not deploy. The warning light just lit up a couple of days ago. As soon as I am sure I've got all the terminology correct, I'll call those guys, thanks!
  4. Metalman
    Check for terminal corrosion.... MINI's have been known to have problems in that area... Might also check for corrosion at the + battery terminal connection at the engine firewall (under the black plastic cover).... Could be the ECU isn't getting a good reading and throwing a fault...
  5. davavd
    6
    Architect
    Covington, La
    I replaced the battery about 3 weeks ago. I'll check that terminal up front.:Thumbsup:
  6. Metalman
    Did the light come on shortly after the battery was replaced?
    Pull the black cover off the explosive battery disconnect (see video) and inspect for corrosion around the cable disconnect just to make sure there isn't corrosion in the joint that is supposed to separate......
  7. MCS02
    There is a recall for airbag wiring on the Gen 1 minis. I can't remember what years were effected. I would give Mini USA a call before I do anything els, give them your vin and they can tell you if your car is affected.
  8. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    Recall notice 15V-205 M650215 seat mat OC3
    Mine was done a year ago last April.
  9. MCS02
    My to had a recall for the right side wiring harness. but that was along time ago.
  10. wmwny
    4,048
    2,246
    I had my airbag wiring replaced this year on my '06 MCS, as well as that on my wife's '06 MCS, both under the recall.
  11. davavd
    6
    Architect
    Covington, La
    No open recalls found.
  12. MCS02
    Sorry, I thought you may get a free fix.
  13. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I had mine done over a year ago...and the stealership REALLY screwed my passanger upholstery. Their response..'oh well'.
