Engine Drivetrain 2nd Gen S Akrapovic Delete-R does it work?
Discussion in 'Tuning and Performance' started by AM_AUTOS, Jun 12, 2013.
  1. AM_AUTOS
    AM_AUTOS New Member
    Dec 27, 2012
    137
    106
    UK
    Hey everyone
    I keep getting the P0420 code after fitting a sports car and i dont want to remap my ECU
    Who has this on their car and does it work?
  2. Jason Montague
    :cornut: No help here mate but I'll bump your post.:Thumbsup:
  3. ScottinBend
    I assume you meant sports CAT?
  4. minidiver
    minidiver Member
    Jun 24, 2010
    31
    You need an oxygen sensor simulator. Easy to install and works great. Just google it and the company will come up. They make a MINI specific model.
  5. Metalman
    Way Motor Works sells them..
    You might want to send him a message...
    It's not an uncommon fault code due to the reduced cel count in the sport cat...
    Since Akrapovic sells this piece in addition to their down pipe.... The assumption is it works to trick the ecu....
    The other direction is to go with the O2 simulator... it's a simple spacer that moves the O2 sensor a little farther out of the exhaust stream....
    Here...O2 Simulator, mini catalytic Converter cel fix
    Sorry, I have no experience with either of these items...
  6. AM_AUTOS
    AM_AUTOS New Member
    Dec 27, 2012
    137
    106
    UK
    Yup i installed a sports cat - 200 cell one on my 2011 JCW
    Well i tried an o2 spacer and it didnt work - Still the EML light
    The shipping for that other space is $80 then $30 and no returns if it doesnt work
    At least if the delete R doesnt work i can get my monies back
    Thanks metal man i will drop Way motors a message
    :Thumbsup:
  7. wzabrouski
    wzabrouski Active Member
    32
    Executive Director
    Keller, TX
    I have the delete r and the Akrapovic DP. I still get the light with the P0420 code ever few hundred miles but it clears it self, then comes back a few hundred miles later.
  8. wzabrouski
    32
    Executive Director
    Keller, TX
    Also I tried the spacers. No dice.
  9. AM_AUTOS
    AM_AUTOS New Member
    Dec 27, 2012
    137
    106
    UK
    As long as it goes out itself its all good
  10. minidiver
    minidiver Member
    Jun 24, 2010
    31
    The O2 sensor simulator is a small circuit board that you wire in instead of the rear sensor. It sends a signal to the ECU that it accepts and you get no check engine lights. I ran one on my last car with an empty cat on my header and never had a code.
