Alignment question
Discussion in 'Mid-Ohio Motoring' started by JW34, Mar 2, 2014.
  1. JW34
    JW34 New Member
    Oct 25, 2010
    40
    Central Ohio
    Any recommendations for a good place to get an alignment around Columbus?
    (No, not that kind of alignment Chuck!)
    Thanks.
  2. Jason Montague
    :cornut: I'll bump you to keep you up top until MoM gets back.:Thumbsup:
    Northend Wrench Tel. 614-263-4978
    They do good work John. :D
  4. DneprDave
    #4 DneprDave, Mar 2, 2014
    Around here, the MINI dealer is the cheapest, about a hundred bucks.
    Dave
    What I like about the Northend Wrench is the fact they will do custom alignments. Once you mod the suspension an oem spec alignment just won't cut it.
  6. CHKMINI
    +1 on Northend Wrench. I also use IPS Motorsports in Lewis Center.
  7. JW34
    JW34 New Member
    Oct 25, 2010
    40
    Central Ohio
    I didn't know Northend did alignment. I'll check them out. I may see what MAG charges just for grins.
    Thanks for the info!
  8. Dave.0
    OEM is ok and cheap but if you have done anything to customize your suspension a custom alignment is 1,000 better.
  9. mrntd
    Tire discounters in Hilliard will do a custom alignment. The one in Reynoldsburg will do it with you in the car.
