Alignment
Discussion in 'Mid-Ohio Motoring' started by BetaMini, Jul 19, 2015.
  1. BetaMini
    BetaMini New Member
    Aug 2, 2012
    218
    98
    eComm
    New Albany, OH
    Hey all, where do you take your MINIs for alignments?
  2. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Performance Alignment In Cincinnati, OH. They really know their stuff. It's worth the drive...
  3. Dave.0
    Not The Dealership. :lol:
    I've used the North End wrench for both my Miata & my MINI. They will set your alignment to whatever you chose. They are very familiar with track cars so you won't have to hear "that's not what our book says".... My .02 is since this is a street driven car don't go to crazy with your alignment.
  5. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    The curbside by my house.
  6. BetaMini
    BetaMini New Member
    Aug 2, 2012
    218
    98
    eComm
    New Albany, OH
    Right. Was looking at going with:
    F) zero toe, -1.5 camber
    R) zero toe, -.75 camber
    Sounds good, but if you are headed to the track for the first time I think I'd add a bit more rear camber. Just my .02.
  8. BetaMini
    BetaMini New Member
    Aug 2, 2012
    218
    98
    eComm
    New Albany, OH
    I've read a lot about settings people use. Definitely quit a bit to think about. I got those settings from a post Helix commented on - re: best compromise between street/track.
    Was also looking at this from CCT1:
    F) zero toe, -2.0 camber
    R) slight toe in (1/16), -1.5 camber (toe helps with high speed stability)
  9. BlimeyCabrio
    I'm a BIG fan of a little toe in on the rear, as CCT1 suggests. I've run with just about every combination of toe and camber.
    I generally recommend 0.5 to 0.75 LESS negative camber in the rear, than in the front.
    If I was running -1.5 front, I'd probably opt for -1.0 rear.... but that's just me. 0.25 camber isn't really much difference, one way or the other.
    For my mountain and track setup, I run with just a touch of toe OUT on the front to help with turn-in. But it will eat tires on a street car.
  10. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    If I do say so my self, Detroit Tuned does a good alignment and we can advise you on what works and why, as well as put you in the car while we do it to get all the wights correct. Also have a full tank of gas and good tires with the correct air pressure.
    Chad
    Detroit Tuned
  11. Metalman
    This I know from experience....:Thumbsup:
    Except I'm not sure I got any wights..... Still lookin for the wights... Am I missin my wights?:eek6:
    Be very careful Chuck If your headlights burn out you'll be a dim wight..... :D
  13. Metalman
    ^^^ Are you sayin I'm not there yet?:)
  14. MCS02
    Not to high jack the thread. Here is my setup. I told them I wanted stock toe on the front but he said something about changing it for turn in. Can someone tell me witch number is front toe? I don't want my tiers worn out.
  15. cristo
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    #15 cristo, Jul 20, 2015
    I'm guessing front camber, caster, (?max steering angle?), toe
    then rear camber, toe going down the readout.
    Front toe would be -0.04 left, -0.06 right, -0.09 total
    (doesn't add up exactly, probably because of a rounding error)
    Usually with toe, toe-in is a positive number, toe-out is a negative number.
    Yours has a small amount of toe-out. This small amount will likely improve
    turn in response without sacrificing high speed stability much. More would
    make a street car squirrely on the highway.
