Engine Drivetrain 2nd Gen S Amsoil
Discussion in 'Tuning and Performance' started by COOP310, May 23, 2011.
  1. COOP310
    COOP310 New Member
    May 12, 2009
    34
    Lake Mary, FL
    I have 5 quarts of Amsoil European Car Formula 5W40 laying around the house and the car is due for an oil change. It says it meets ACEA A3/B3-04, ACEA a3/B4-04 as well as BMW LL-04. Is this ok to use on an R56 S, or do i need to use the 5W30?
  2. jcauseyfd
    jcauseyfd New Member
    May 25, 2009
    201
    31
    Graham, NC
    I would contact Amsoil directly to see if they can advise as to the proper oil for your application.
  3. ScottinBend
    Yes you can use it, if you want to save a bit of money. But I myself would never buy Amsoil again, especially for the price.
  4. COOP310
    COOP310 New Member
    May 12, 2009
    34
    Lake Mary, FL
    Im curious as to why, and what you do use.
  5. ScottinBend
    I would never suggest to anyone that they use these "boutique" oils (Amsoil, Redline, Royal Purple). I have been using Mobil 1 and Castrol synthetics for over 35 yrs in all of my cars. I usually send a sample of my oil from each of my cars to Blackstone for testing every year or so. So far with the oil change intervals I use, once a year regardless of mileage (our cars are only driven between 7-10K miles per year) there have been no issues. I don't do any track days in the MINI right now, but I never saw any problems with the oil when I was doing a couple of them a year before.
    My previous car was a '78 VW Scirocco with 165K miles and it was driven hard for most of it's life. Lots of AutoX and a few hillclimbs. It was on Mobil1 for most of it's life and was still running strong when I got my MINI 25 yr's later.
    That's proof enough for me.
    I can't see spending twice the money on oil for arguably no benefit.
  6. COOP310
    COOP310 New Member
    May 12, 2009
    34
    Lake Mary, FL
    I really wouldn't even have this oil if it weren't free. (door prize) just trying to figure out if it's ok, or if I should go for the factory oil.
    Is the MINI still under the factory warranty?
  8. COOP310
    COOP310 New Member
    May 12, 2009
    34
    Lake Mary, FL
    No. 57,000 miles
  9. Nathan
    Given that you are beyond the warranty period and it does meet BMW/MINI specs I'd go ahead and use with some caveats. Since it is a 5W40 as opposed to a 5W30 I would plan for another change before the cold weather sets in. But being you are in Florida I would think that unless the winter is unseasonably colder than usual you should be OK.
    Please keep in mind these are my own thoughts on the matter.
  10. rckrzy1
    rckrzy1 Member
    Jul 14, 2015
    34
    11
    AMsoil practically INVENTED the Synth oil and in no way should be classed with the other mentioned. I have tested it for wear over the years and blackstone labs find it is superior for wear than any other oil tested.
    I run it in my motorcycles and would use in my car if the cost was not so high.
    Mobil1 change their formula a while back and I saw engine wear creep up on a V8 I owned, switch oil and wear decreased and just to prove it, ran mobil 1 for a short run of 3K and damn if wear was not back to higher. Never again for me, the newer European blend might be better but I'm not beta testing my MINI.
  11. Dave.0
    I run Amsoil and nothing else. Quality oil is cheap insurance for expensive motor mods.
    (Big Valve Head and Cam)
    Also yes that oil is fine for your MINI. I will never run Royal Pimple crap or Redline.
    Castrol Euro is ok and I just don't like Mobile 1 since they changed it.
  12. DneprDave
    How can you test if your engine has more wear If you don't take it apart and measure it?
  13. Stinch
    Stinch New Member
    Jun 24, 2015
    24
    21
    Trumbull, CT
    I've got a case of Amsoil European 5W-40 Full-SAPS Synthetic coming that I'll put towards my next oil change.
  14. rckrzy1
    rckrzy1 Member
    Jul 14, 2015
    34
    11
    Blackstone labs, a professional Oil analysis , it measures metal and other contaminants in your oil, and by knowing what cams, bearings, pistons etc are made of they can tell you what is wearing.
    Cost about $25 a test , $10 more if you want them to tell you how many more miles you can run or not, as in I sent oil in from my 2013 at 7K miles on the oil, their testing showed the additives, cleaners etc would be ok for another 1K miles, so 8K is a good mileage to change and proves MINI's service intervals of 15-16K is going to hurt your motor.
    I have an oil extractor which makes it very easy to pull the few ounces needed for testing, or you can just test at your oil change. They will mail you a free test kit for collecting sample and for mailing.
    For years I have not GUESSED at oil , and in over 40 yrs of owning cars never suffered an internal failure or burning oil. My 2013 which I bought new uses maybe 1/8 qt in 8K miles.
    They also look for other contaminants like coolant/water and gasoline. You can really get a good look at the status of your motor by testing oil, kinda like having a full work up on your blood.
  15. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    ^^Good post rckrzy1. Most people that whine about oil brands have never done any UOA and are really just playing emotional brand favoritism. The only way to make an informed comment is to do a variety of VOAs and UOAs over a long period of time.
  16. ScottinBend
    Exactly what I do with my 2 cars.
  17. MCS02
    6,278
    Perhaps I will try them.
