1st Gen R53 Cooper S An exhausting question...
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Goldsmithy, Sep 17, 2015.
  1. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I have a R52 S (automatic)with a 15%pulley , DDM CAI, and a Jan tune. The next step is the exhaust. And my confusion starts...
    Is there any benefit to a cat back exhaust in terms of a scavenging and flow rates... or is all about 'sound'.
    And in terms of low back pressure and flow rate, what is advantage of a 'tuned' header? Depending on responses, if a do the header, it will be the RMW street header.
    BTW, I wear 2 hearing aids, and sound is unimportant to me.
  2. ScottinBend
    Why exhaust? Power?
  3. Zapski
  4. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Engine efficiency.
  5. Savvy
    May not matter to you, but passengers, neighbors, and local police will certainly care about the sound.
  6. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Agreed... But i'm not THAT radical;. :)
    What ever you do, do the opposite of the exhaust on Gnat. :wink:
    I had a JCW exhaust on mine & liked the sound. A bit louder but not obnoxious, no highway droning.
  8. Metalman
    Yeah.... That system is blown out and WAY TOO LOUD....:crazy:
  9. MCS02
    6,278
    I believe their is an advantage to headers and exhaust. You may lose a little torque with headers or so I am told but gain some HP. Have you asked Jan if the tune will have to be tweaked?
    On a street car I'd go for more torque. You'll be the torque of the town. :D
  11. BlimeyCabrio
    What you want is RMW shorty / street header, plus RMW cam and tune. THEN you'd benefit from a JCW or Miltek exhaust. Exhaust before header won't buy you anything except a little sound.
  12. mrntd
    The stock exhaust does have some restrictive bends in it and restrictive mufflers. So another exhaust may not get you but a few horses. I've read about 5hp. Not enough to tell by the seat of the pants. So the added benefit is the sound.
    Jan said, when I had mine tuned, that I would not need to retune it by adding a header and a high flow cat.
    Now on turbo cars it's different getting rid of any back pressure is beneficial.
  13. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    I think I can safely say I have more modified miles on my car than 99% of the cars on here (15% pulley/ RMW cam/ header/ Jetex cat back exhaust (over 110,000 miles)on these/ Vipec ECU (50,000 +miles driving on the vipec).
    I reinstall the stock header / exhaust every two years for smog. The difference with the swap is silly. The car feels very lethargic in comparison - the header really helps the motor breathe even on a stock head.
  14. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Thanks for the advice everyone...it was just what I needed. I have decided to not decide on an exhaust, at the moment. Now, to get to work on the trailer...
  15. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    Real solution is opened up exhaust ports in head (ala JCW head or aftermarket grind job), free flow header to get the gases away from engine, and free flowing dual exhaust per what your ears can stand (I use street Milltek which is only mildly offensive to tender ears). BTW, stock exhaust is NOT a dual exhaust...so aftermarket dual exhaust will breath better.
    After above hardware then have a tune done which will alter the rest of the system to take advantage of the better breathing.
    In my case I gained a good bit of power throughout the range in addition to increasing fuel mileage economy by 6 mpg...in spite of moving to larger fuel injectors at the same time. Impossible to point to any one item as the cause for the increases...I saw it as a complete system upgrade.
  16. BlimeyCabrio
    THIS
    I've been swapping the stock header back on annually. The difference is night and day, with the RMW header.
  17. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    #17 Qik, Jan 14, 2016
  18. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    There are a couple, but not ones that I would recommend. In terms of cat back exhaust, where sound is the chief factor, The conversation begins and ends with Milltek in my book. They caught lightning in a bottle with that exhaust.
  19. Dave.0
    Milltek #1.
    It's what I have had for years based on Eric @ Helix recommendation and I could not be happier after all these years.
    (NOT the knock off Strat version)
  20. mrntd
