2nd Gen R56 Cooper S Another annoyance...
Discussion in '2nd Generation: 2007+ R55 through R61' started by e46tor56, Jul 27, 2013.
  1. e46tor56
    e46tor56 New Member
    Nov 3, 2012
    357
    BMW/MINI Parts Advisor
    So ever since I've bought Bella the gas filler door does not lock when the vehicle is running. Is this typical? Shouldn't it be locked if the doors are locked?
    What annoys me is when I take her thru a touchless car wash the filler door flies open from either the high pressure water or from the drier. I'm at the point of ordering a Justa filler door and swap it.
    That's normal, I was my car by hand because the chemicals in those touchless carwashes destroy your paint, clearcoat and strip you car of wax.
  3. CamtheWookie
    CamtheWookie New Member
    May 17, 2009
    131
    32
    Huntersville, NC
    Is that true? For all that, it's pretty amazing how poor a job they do of actually cleaning the car. :eek:ut:
  4. Dave.0
    Yup, they use some nasty stuff.
  5. CHKMINI
    The pre wash cycle at touchless and high pressure wand washes is merely highly concentrated detergent that will strip all wax from your car. It is also abrasive to assist cleaning through high pressure. Stay away...Stay away...Stay away!!!!
  6. old81
    1,542
    Actually, not all the above is true. Some of the touchless washes are pretty good.
    I have found a few washes that use friendly chemicals and still do a reasonable job of getting the MINI clean. In Colorado, you need to run through a power wash since we use Magnesium Chloride on our roads for ice in the winter.
    The only way to get underneath and get the MC off you have to rely on the brushless wash and the high pressure from below.
    Not saying all touchless are great, I select mine carefully, I am lucky that I have a decent one close to my home. It has the option to use a generic polymer finish wax and a rainx solution rinse.
    Of course, I use Hydro as I dry, about 99% of the time.
    IMHO.
  7. CHKMINI
    Everything is clean in Colorado.....here in Ohio we aren't. Hell, we had the Cuyahoga River catch on fire once!!
  8. Metalman
    ^^^ Once?
    Hah... at least 13 times....
    "Kill It With Fire"....
  9. e46tor56
    e46tor56 New Member
    Nov 3, 2012
    357
    I only use the touch less when I really have too. In this case I was washing off a large pile of bird poo.
  10. ScottinBend
    Since when is it normal for the gas door not to lock when the car is in motion?
  11. Dave.0
    If the doors are locked the gas cap is locked. When you stop and unlock your door it also unlocks and the gas cap.
  12. ScottinBend
    From your first post it seemed like you were saying that the door in not normally locked with the doors.
  13. e46tor56
    e46tor56 New Member
    Nov 3, 2012
    357
    #13 e46tor56, Jul 31, 2013
    I lock the doors when I go thru the car wash and the filler door flies open when the air from drier hits it. This doesn't not happen in my Justa.
    I know the filler door locks because I've checked it when the car is locked. I find it weird that its not locked when I go thru the car wash. Anyways
  14. ScottinBend
  15. e46tor56
    e46tor56 New Member
    Nov 3, 2012
    357
  16. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    Maybe coz R56....race car????
