Anyone with an ACT clutch want to share their expierence? I know a few people have them and i hear they do not rattle and offer good driveability. Thanks, Jonathan
I have the ACT flywheel, but at the time that I bought mine, the pressure plate and disk were not avail. Nonetheless, I can give you my opinion on that. The flywheel is a really good piece. I recommend it to replace a worn out dual mass unit. They are 2lbs heavier than their aluminum counterparts. ~13.5lbs (i think) Solid steel - no replaceable inserts. Engine revs are much quicker and engagement is much, much better. (read, better feel) You mentioned the rattle/chatter... mine did it right off. However, I have replaced other cars' flywheels with this one, and they didn't. I think it depends on your trans., cosmic alignment, etc. And i'll add that I have installed numerous ACT disk and PP combos and have never had a complaint.
I've had mine in for two years with no problems. The flywheel while it doesn't have a replace able insert it can be resurfaced. So it is reusable. Mine doesn't chatter I used redline lightweight shockproof oil in the trans. I would recommend it.
