2nd Gen R56 Cooper S Any quick fixes for yellow engine light?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Zapski, Jul 1, 2014.
  1. Zapski
    So I got one of these this morning, and needless to say it couldn't come at a worse time.
    Is there anything quick and easy I can check, or am I doomed to take it in?
    Check your oil and everything else.
    Or you could drill out the light in your dash but that may look a bit messy.
  3. Zapski
    Oil's a bit on the low end of the stick, but not below the lower mark. Coolant is just fine. The only thing that's low is the washer fluid. :)
    If you are still under warranty swing by the dealer. Have them read the code & proceed with the repair. If not read the code & report back here for more help. If you can't read the code swing by Best Motor Werks & ask John to read the code for you. Report your findings back here.
    If all of the above can't be done use some black tape. Much cleaner than Dave's suggestion & 100% reversible. :D
  5. Zapski
    Oh, she's well out of warranty. I'm nearly at 100,000 miles.
    I'll drop by Best tonight.
  6. DneprDave
    Take it to an Autozone, they will check the OBD2 codes for free.
  7. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    When my SES light came on, I took the MINI to Autozone to have the code scanned (free, and open on Sunday), and read. Their scanner threw out a P113C code. They could not find anything for that code in their database. I took it to a mechanic that I trust, and he had to hook it up to a laptop with BMW Code "reader" installed. Turns out that it was a bad oxygen sensor.
  8. Zapski
    Good advice. I'll do that over lunch. Thanks!
  9. Dave.0
    Autozone tool are useless for specific Manufacture codes.
    One of these works great and they are cheaper now only $179.
    I have the $287 enthusiasts version and it works with a PC laptop (no Apple) and you can even reset the adaptives. Its says you can only use it for 1-3 cars based on VIN # but if you never register a VIN you can use it on as many cars as you want and I have. :Thumbsup:
    See Link option #3
    Bavarian Technic Software - Products for sale
    If it is a generic OBD II code Autozone may pick it up. Like has been said mfr specific codes will not. Call John Best & see how late they are open. Tell John Crashton sent you from M/A.
  11. Zapski
    I'll have to drop it off tonight after they close, I get out of work well after they're done for the day. I've been there before, they replaced my clutch a couple of years ago, did a nice job too. :)
    Great folks at Best. :Thumbsup:
  13. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    They are pretty damn awesome.
    Even said my Mini is the quietest one they have had in the shop, lol.
  14. Zapski
    Stopped by Autozone over lunch, and they were very happy to hook up the reader. Sadly it reported "No Codes."
    *sigh*
    I bet this is going to be either something stupid like a loose hose, or something terrible. There's no in-between.
    Hoping it is cheap & stupid. :fingerscrossed:
  16. Dave.0
    Sounds like what I used to wish for on some dates. :ihih::lol:
  17. Zapski
    Just heard from Best - John's not sure yet what it is. It might be a bad waste gate, so he asked permission to do a little more diagnostics than usual.
    Here's hoping.
    :fingerscrossed: Still hoping for a dumb easy fix for you.
  19. Zapski
    Sooooo. bad news. It's the turbo assembly which needs to be rebuilt. It's going to cost well over $2,000 and I think it may inspire me to actually sell the car once it's done.
    I can't keep putting that kind of money into it every year or so. I just don't have the means.
    That's a big bite in the wallet. Are you done with MINI's?
    Any ideas what your next ride will be?
