Engine Drivetrain 2nd Gen Any way to get a little more power?
Discussion in 'Tuning and Performance' started by ammodave, Sep 4, 2010.
  1. ammodave
    ammodave New Member
    Dec 16, 2009
    NW Fl
    I have a 4mos old justa that suits me just fine but I wouldn't mind having a few more hp. I know I could have gotten an S but the whole runflat tire issue steered me to a plain jane. I see a few CAIs available; do they really produce more power? Any dyno charts out there to show what an intake or a tune can provide?
  2. Minidave
    4,592
    There are always compromises.....
    Have you tried your "Sport" button?
  3. Justa Jim
    There is a thread talking about this very thing and I saw it this morning, but I can't find it now. It is tucked in a forum someplace, so I'll keep looking.
  4. lotsie
    stagehand/part time detailer
    Right here
    And when you find it, make sure to let me know. Oh dear, this is 2nd gen:beer
    Mark
  5. RonsMinnie
    RonsMinnie New Member
    449
    Sugar Land, TX
  6. cal330ci
    cal330ci New Member
    Aug 30, 2010
    38
    Automotive Technician
    Vancouver BC
    Not too many choices on the standard Cooper. I have seen a few modified R50s but nothing really yet in terms of R56 Cooper. CAI is an obvious choice as well as free flow exhaust. Maybe someone knows about aftermarket software/tuning.
  7. Minidave
    4,592
    I always wonder when a Justa owner starts asking for "just a little more" power what they're really after?
    I mean that as a sincere question, not any kind of a putdown.....
    Would 5hp do it? 10hp?
    When you start buying exhaust systems, cold air intakes, aftermarket tunes, camshafts and so on, pretty soon cost wise you could have bought an S, and you still don't have the same HP as a S model does.
    That's not to say the S doesn't have it's compromises too - the OP notes the run flats issue, which means buying a set of wheels and tires to get around it.
  8. lotsie
    Right here
    For most of my 03 justa mods, it is replacing worn out OEM stuff. I guess the gain is maybe 5-8 hp with intake/exhaust, on a good day. It is pulls good from 2000 rpm+, so I'm happy. No tune. S owners have to work to keep up in real tight twisties:D
  9. MiniJimi
    MiniJimi New Member
    Jul 20, 2009
    35
    6
    West Virginia
    I added the DDM CAI to my 08 Clubman. Hasn't really provided any 'noticeable' power improvement.
  10. ammodave
    ammodave New Member
    Dec 16, 2009
    NW Fl
    An extra 10 hp would certainly be welcome. I know I could have bought an S but the melting hood scoops and run flat tires (that nobody likes ) were the final straws that tilted me toward the justa. The tires and hood scoop are both examples of form over function. The hood scoop is attractive but it serves no purpose. The S exhaust could have easily been routed to make room for a spare and allow Mini to fit some good rubber to to the car. Call me old fashioned but when I'm in the middle of nowhere with no cell signal and a badly damaged tire, I'd like to have a spare.
  11. Justa Jim
  12. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    We've used and installed the DDM Cooper intake and even did dyno tests with it. It gained 8 ft lbs torque at the wheels. So I'd definetly recommend starting with it. Also the NM lower torque arm bushing is a must have mod on all R56's
  13. ammodave
    ammodave New Member
    Dec 16, 2009
    NW Fl
    #13 ammodave, Sep 5, 2010
    I already have the torque arm bushing (think I bought it from you). I note from your website that the DDM intake uses the oem cold air tube/silencer; is there no benefit to replacing the oem tube? Could you post the dyno printout for the DDM intake?
  14. lotsie
    Right here
    One of these days I'm going to do all the motor mounts. The top mount engine damper I have on the 03 does butt dyno test as a good addition.
    Mark
  15. Minidave
    4,592
    Just FYI, there's a spot for a mini spare under the floor of the Clubman - including the S that I have.
    Truthfully tho, I've had non-runflats on both of my Coopers pretty much since I got them and never had a problem with a tire - *touch wood*.
    I've done a number of cross country trips too - trips to Mini-sota, South Dakota and Wyoming, Colorado, Arkansas, North Carolina and all over Kansas and Missouri. I might be tempting fate by even mentioning it, but so far......
    My point about the HP is, it's fine to add CAI and exhausts for sound and so on, but they make so little difference - you have what you have, if you want more it's probably going to be more cost effective to buy an S than invest more in a Justa....
  16. cal330ci
    cal330ci New Member
    Aug 30, 2010
    38
    Vancouver BC
    If you dont use run flats just keep an emergency tire inflator kit and you ll be ok.
    Just keep it simple of Justa, CAI and exhaust and you ll never have any problems
  17. Justa Jim
    I know it has been said before and there are disbelievers, but add the sprint booster with the torque arm bushing and you get more go then you had before from from the sport button. Add the DDM intake and you get a bit more. I just don't buy the "what you have is what you have" statement at all. Will it be an "S"? No, of course not. Can you still get more performance? Yes.
  18. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    I too
    don't buy the "just get an S" mantra. I mean, if you wanted a fast car, why buy a mini at all? All those that mod Minis could be told "just should have bought a Porsche, or a turbo Solstace, or a fill in the blank....
    But that said, it sure is harder to mod the base Prince engine, just like it's harder to mod the base Tritec. A much smaller percentage of the buyers are interested in improving power, so there isn't a ton of reasons why sellers will make parts for the base engine.
    Then again, it's just an engine. Talk to those that improve engines, break out the checkbook, and have at it! Port the head and intake. Throw on some bigger valves. Get a camshaft (or two for the Prince) and go to town.....
    Someone has to be first...
    Matt
  19. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Well the stock S is much quicker to 60, 2 seconds, which is what like 30% faster? That is substantial. No way to get near that with bolt-ons. So I differ with you on the "S mantra" :cool: There are not many cars out there that I see driving the streets that are as, quick, good handling, solid feeling, economical, versatile, and nice looking as my wife's Mini S :Thumbsup:
  20. Justa Jim
    Keepimg everything in the MINI arena it comes down to the fact that the "S" is faster in a direct line (like 0 to 60), but the justa gets better mpg in a direct line. Other then that, in given conditions, they perform in a simular manner. My point is only that the stock justa CAN be improved a bit. Not to become an "S", but better then stock. It is not a "dog" by any means.
