2nd Gen R56 Cooper S Anyone clean out their MAF?
Discussion in '2nd Generation: 2007+ R55 through R61' started by KittyMini, Oct 3, 2011.
  1. KittyMini
    KittyMini Club Coordinator
    1,183
    #1 KittyMini, Oct 3, 2011
    I was going to have the hubby do it the other day, but it doesn't look like there's a way to pull it apart... it seems like it's one piece?
    Crap- so I found a thread on here that Jim started about MAFs, but none of the pictures/links are working on it. :mad2:
  2. Justa Jim
    Kitty, here is the link showing yours. It is part #13 and looks to be the same as mine, but I can't swear to that.
    http://www.realoem.com/bmw/showparts.do?model=MF73&mospid=50031&btnr=13_1212&hg=13&fg=20
  3. KittyMini
    1,183
    Thx Jim... but how do you clean it?
    Is the sensor in the plastic housing?
  4. DneprDave
  5. Justa Jim
    The link that DenprDave shows the MAF housing. I did NOT remove mine from the housing, having been warned how delicate the wires are. You see the grid at the front, but the back is open and you can look in and see that the sensor is toward the front and a little off center. I took a spray can of CRC MAF cleaner, with a plastic tube attached and sprayed it through the plastic grid openings, soaking the sensor. It says NOT to touch the wires, just spray it on and let it do the cleaning by itself. It seemed to work for me and was not hard to do.
  6. BThayer23
    Leave the MAF together, so it looks like a tube with some wires inside and grilles on the end. Don't unscrew the torx (star-shaped) screws. The only things you're disconnecting are the sensor wires and the hose clamps. Spray CRC MAF Cleaner into the tube, aimed towards the thin wires, and let it dry before you reconnect it.
    edit: Didn't refresh and see Jim's post. That's the ticket.
  7. KittyMini
    1,183
    Nice. Thx guys!
  8. gds194
    gds194 New Member
    Sep 26, 2011
    281
    None
    Centennial CO
    I have used Q-Tips to clean the sensor on my Toy and Lex w/o a problem,,,, you just need a light touch!
