Brakes Wheels 2nd Gen Tires Anyone running 215 tires?
Discussion in '2nd Generation: 2007+ R55 through R61' started by KittyMini, May 13, 2010.
  1. KittyMini
    KittyMini Club Coordinator
    1,183
    I was looking at getting summer wheels/tires for the MINI. The tires I want don't come in a 205... 215 would be the closest. Would these rub?
    Also, is anyone running Team Dynamics wheels? I'm a little confused on all the sizing specs (like 35mm?). These are one wheel I am considering.
    Soooooo, any help/assistance would be great.
    Thanks.
  2. track-toy
    track-toy MINI of the Month
    Test Driver
    Pittsburgh, PA
    I haven't run the team dynamics wheels, but I run 215/45/17 on the street and 225/40/17 on 7.5 inch rims on the track. I only used the stock 205s for my first set in 2002/2003. Never went back to 205s.
    I hope that helps!
  3. CHKMINI
    I'm running 215 45 17's on my lowered JCW without any rubbing issues.
  4. BlimeyCabrio
    Been running 215/45R17's for about 60,000 miles and 4 sets of tires. Love 'em. No rubbing on my 1st gen car lowered about an inch all around, even when fully loaded with four people and gear.
  5. ra2fanatic
    ra2fanatic New Member
    Mar 15, 2010
    17
    i'm running 215/35/18s. i havn't had any issues rubbing....
  6. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    I have 215/45 17's on 17x8 TD Pro 1.2 wheels. Offset is 38mm
  7. Jabbles
    Jabbles New Member
    24
    HVAC service
    Sarnia, Ontario, Canada
    215/35/18 no issues here, stock ride height.
  8. Boxcars
    Boxcars New Member
    May 27, 2009
    80
    am running 215/45R17's on a TSW lowered 05 MCS
    only a tiny rub with 2 people on an extreme bump.
    barely noticeable.
    boxcars
  9. wmwny
    4,048
    2,246
    I have 215/50/16s and have no rubbing issues. I also have a very worn set of 6 205/50/16s that I plan to burn off this year at the track...then, it will be 215s from now on.
  10. KittyMini
    1,183
    Do you all think there is a difference in the 1sr gen vs. 2nd gen for this?
  11. Jabbles
    Jabbles New Member
    24
    HVAC service
    Not sure, mine is a first gen and as mentioned it has no rubbing issues.
  12. track-toy
    Test Driver
    Pittsburgh, PA
    2nd gen runs about 10mm higher than 1st gen. My 1st gen car is on coilovers and 215s with 15mm lower than 1st gen stock. No rubbing.
  13. oxtox
    oxtox New Member
    May 12, 2009
    52
    hey monica,
    i had 215/40/17's and did have a rub on my front strut body, 5mm spacers fixed that, but then i had a rub on the rear wheel well/trim which quickly burned itself clearance. i'm lowered about 1.5 inches on bc coilovers with swift springs.
  14. Doggybags
    Doggybags New Member
    You will be fine on a 2nd gen, there's plenty of space. On a 1st gen it would probably depend on the tire model and the height of the tire wall (45 vs 40 for our application).
    It is important to recognize that the same measurements actually vary between tire models. For example, there are those than can run on lowered cars with 215/45's and have no rubbing. I have a stock sport suspension (1st gen facelift 2005 R53) and run on the Dunlop Star Specs with 215/45's with some rubbing on the outside of the tire during high compression loads (high speed bumps, for example). I used to have the Dunlop Direzza's Z101 in the same size and had no rubbing whatsoever. The Star Specs are known to be a wider tire for the same width measurement.
  15. BlimeyCabrio
    Yep - tire profiles vary pretty significantly. The Tire Rack site has pretty good measurements for "overall width" and "tread width", etc. But that still doesn't account for some tires that have a "squarer" profile than others.
  16. KittyMini
    1,183
    Thanks guys... good to know.
    Here's question number 2:
    What does all this mean????? It was on the site where I was looking at Team Dynamics. Which, if I chose this wheel, should I get?
    I just have a stock setup right now, and am looking at either 205 or 215 tires, on a 17" wheel.
    Thanks guys :D
    7.0 x 14 from 12.5lbs e+35/38/40
    7.0 x 15 from 15.1lbs e+15/20/25/30/38/40/45
    7.0 x 16 from 16.2lbs e+15/18/20/25/30/38/45 (best for the MINI in a 45mm offset, 4x100)
    7.0 x 17 from 17.3lbs e+15/18/20/25/30/38/45/50 (best for the MINI in a 45mm offset, 4x100)
    8.0 x 17 from 19.8lbs e+20/25/33/37/45/50
    9.0 x 17 from 20.9lbs e+23/30/35/40/
    8.0 x 18 from 19.8lbs e+11/15/20/25/30/35/40/45/50
    9.0 x 18 from 24.2lbs e+15/20/25/30/35
  17. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Monica,
    I've run both 215/35/18 and 215/40/18 on my R56 and even with TSW springs that lower the car about 1" I've had no issues with rubbing.
    I have a set of wheels that have a 42 offset. I'd double check on the offset of the Team Dynamic wheels but unless they are really extreme on the 'depth' of the wheel you should be OK
    Personally I'm wondering if I can go 225
  18. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    using the first choice as a example-the "7.0" is the width of the wheel, the "14" is the diameter of the wheel, the 12.5lbs is the weight of the wheel, the 'e+" is the offset I refer to above
  19. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
  20. Nathan
    The numbers you are asking about are the offset of the wheel. Front Wheel Drive cars such as our MINIs us a positive offset, meaning the mounting surface of the wheel is offset from the centerline of the wheel towards the face. The offset measurement is displayed in mm.
    Diagram:
    The closest to OEM in your case would be the 17x7 with an ET45. With the 215 you could also fit the 17x8 wheel. This would give the tire a more square looking profile and may even, depending on the tire choice, provide what the cool kids call stretch and poke.
    Stretch and Poke...note how the wheel rim sticks out. To many this looks good, on a daily driver if not careful one may curb the wheel causing wheel rash.
    Your best bet would be the 17x7 ET45 wheel, maybe with a pink stripe around the outside edge for some detail.
