Entertainment Electronics 1st Gen Aux In quick question
Discussion in 'Tuning and Performance' started by Gramps, Mar 25, 2013.
  1. Gramps
    Gramps Active Member
    Oct 25, 2012
    US Army Civilian at Fort Sam Houston
    Boerne, Texas
    My 06 MCS has HK with a Sirius reciever in the left side of the trunk. Can an Aux In be added in addition to the Sirius?
    Thanks. Mike
  3. Gramps
    Oct 25, 2012
    Boerne, Texas
    Thanks - I'll get one from Aaron.
  4. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    It's a tricky install but can be done.
    You have to take off the left side down center console tube to get behind the radio.
    In the glovebox by the air vent there is a little plastic rectangular cover that can be removed, I installed the port there and then used a coat hanger thread the cord behind the dash to the radio.
    All you have to do on that 06 is take the torx bolts out of both down tubes. The tubes will drop down. Pull the tops of the tubes toward the side of the car & then you will see the screws holding the radio in. Pull them out & pull the radio out. So simple this old fart managed it.
  6. Gramps
    Oct 25, 2012
    Boerne, Texas
    Thanks all. Old fart-proof is good. Ordering.......
  7. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    If you run into any issues, let us know.
