1st Gen R53 Cooper S B + cable terminal
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Razone23, Jan 30, 2016.
  1. Razone23
    Razone23 Active Member
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    So this past week I took my mini in for a recall on the passenger airbag light. After the work was all set and done, I ended up with one less light to worry about. Yet I still have the air bag light on. I was told I need to replace the B+ cable. Total cost 1,209.20. So my question is does anyone know anything about this cable ? I'm considering on doing this on my own. If I have to return to the dealership in order for them to reprogram or reset something that's fine,but I don't think it will cost as much. But the bulk of the work has been done. If anyone has suggestions feel free to comment. Oh does anyone know of the part number. It's the rear right. [​IMG]
    Ask the dealership for the part number and also has why it's not included in the recal.
  3. Razone23
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    Apparently they said it was a separate incident that didn't have to do with the recall. That was a bit weird. When I read the letter it outline eliminating those lights. So I thought crap that's why I was there for. but it turned out some other issue ?. A piece of black electrical tape over the light and problem solved. But it's gonna bother me, it's like have a dead bug on your windshield,or a piece of popcorn stuck in your teeth. Until it's gone I won't rest.
  4. Metalman
    That price seems ridiculously high...
    Ask them what's all entailed with that repair. And yeah, get the part numbers...
    On the surface it seems like it would be an easy DIY job for you to handle...
    Oh.... And what bothers me worse is bird carp on my paint... That get my immediate attention... Nature's most powerful paint remover right there...
  5. BlimeyCabrio
    Yeah, you need to confirm what wire they're talking about.
    Real OEM Battery cables
    I suspect what they're talking about is the firing cable for the battery disconnect. If the original cable has gotten cut or broken somewhere in the car, there's a replacement cable available, #8 in the diagram at the link above. Though it's different than the picture, the firing cable is part of the body harness and plugs in inside the battery box, it's not part of the main battery cable as shown.
    Or they may be talking about the actual main battery cable, #1 in the diagram.
    If it's the #8 cable, this is routed internally from the battery box, around the interior of the car with the body harness, and eventually back to the airbag module near the hand brake (I think). The bulk of the labor is removing and refitting almost all of the interior of the car. Not technically hard work, but it's work. I've never actually replaced one, so I don't know what work is required at the ABG computer end, whether it's pulling and pushing pins from the connector, or what.
    If it's the #1 cable, that routes under the car. The work is in dropping the exhaust and heat shields, and re-installing. I doubt that's the one, because it should be a lot less labor than the price they quoted.
    In either case, once the fault is corrected, the airbag light will need to be reset using either the factory scan tool, or another tool with BMW/MINI extensions. Lots of folks have that.
  6. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    B+ goes from the alternator to the starter. its included in a full engine harness and its likely 400 in parts and 600 in labor at dealer rates sounds about correct.
  7. BlimeyCabrio
    Colin, look at the RealOEM diagram, and read the thread. It's not what you're thinking.
  8. ColinGreene
    438
    293
    Orange county Ca
    Figures bmw would call it something else.
    Any other car its the alternator back to the battery cable.
