Battery Options revisited
Discussion in 'General Technical Questions and Answers' started by cristo, Aug 26, 2018.
  1. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    #1 cristo, Aug 26, 2018
    It's looking like I should change the battery on my 2009 R55 before winter sets in this year.
    I'd like to stick with and AGM battery in group 47 or maybe 48 (10# heavier).
    I don't have an IBS in this car so don't have to program or register it.
    Most batteries are made by East Penn (Deka, etc.), Exide, or Johnson Controls (now owns Delphi).
    I've had good results with Deka batteries in the past, and hear JC is better than Exide.
    There's also Enersys which makes Odyssey and used to make DieHard Platinum (Sears
    apparently pulled that line recently citing quality issues and excessive returns - does that have
    any bearing on their Odyssey brand batteries?).
    There's also Optima (34R), which seems to have gone down hill since their move to Mexico (and made by JC now?).
    There's also Braille, who make a nice 17# streetable battery which Detroit Tuned sells along with
    a nice mount to hold it securely. They have the brass terminal which I'm not sure about.
    Are these reasonable to use for a daily driver including Pennsylvania winters?
    A lot of people seem to like Odyssey, but their site lists only the group 48 (48-720 or 0752-2020) which
    weighs almost 50#.
    Amazon and others say the Odyssey PC1200MJT fits well but it has brass terminals and only 540 CCA.
    It's lighter (38# like most group 47 batteries). Are the brass terminals a good thing (better conductivity and durability?)
    or a bad thing (galvanic corrosion?).
    There's also XS Power Batteries whose 42# D4700 has more CCA (745) than other group 47 batteries. I can't seem to link this to any of the above manufacturers.
    I know this general topic has been discussed before, but let's give it a go again.
  2. cooperjet
    cooperjet Well-Known Member
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    I went with the Everstart Max from Walmart 3 years ago in my R52S. I don’t drive it much and sometimes go 2-3 weeks between drives. Still going strong. Survived one winter in Ohio before moving to Florida.
    Sent from my iPad using Tapatalk
  3. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    #3 clifforddward, Aug 26, 2018
    Ah, the timeless battery discussion.....Everyone will have a different opinion, so I'll offer mine based on 10+ years driving a R53....
    Mini Cooper S models (at least the R53) are very hard on batteries...and they want full "juice" in order for all the electronics to work properly...so it does not pay to mess around with a battery going weak...
    In the beginning I considered one of the "top shelf" batteries...but experience from my antique car days told me the top shelf batteries were not the best choice for a daily driver...now if I was racing or off road and needed the features that might be another story...
    From the beginning in my Mini I've gone to my local Autozone store, and bought the top-of-the-line Autozone battery that fits the trunk location in my R53...these typically have a 4 or 5 year free replacement warranty.
    Invariably after 2 1/2 to 3 years I get a "little sign" that something is amiss with the electrical system in my car...Maybe it is hard starting one morning...or the window doesn't work as strongly, or some such item. When this happens I immediately go to my Autozone store and 100% of the time the battery has lost a cell or failed for some such reason...and I get a new battery gratis! Now that battery lasts another 2 1/2-3 years when I go through it again. Of course this time I have to pay because by this time I'm out of the original warranty period.
    So I've had four batteries in my Mini during the past 10+ years and paid for two....a bargain to my way of thinking and I've never had the car fail to start or stuck on the side of the road due to a weak/failed battery.
    I'll repeat one important point...know your car and when you get the "little sign" that something is amiss electrically with the car, DO NOT WAIT before going back to the store....if you get the sign (such as hard starting one morning), and don't respond for 2 or 3 more weeks, don't blame me for being left on the side of the road....
    I do this with Autozone because they are very close to me...I imagine the other chains (O'Riley's, Advance, etc) all have a similar deal on batteries.
  4. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Thanks for the advice.
    No ominous signs or even hints yet,
    but the resting charge is down to 12.25V,
    and that’s at 80F.
    I did have sudden failure of a cell about 10 years ago in my previous MINI (2003 R50),
    and no hints of failure until I came out of
    a movie theatre to a fully dead car that
    couldn’t be jump started, although strangely
    enough I was able to push start it, and no,
    I didn’t leave the lights on.
  5. Dave.0
    Good advice in this thread. MINI’s like batteries as much as they like fresh oil.
    I am on my 3rd battery in my 05 JCW. One OEM, one redtop Optina AGM AND now on a Odyssey AGM. I use a NOCO Genius battery tender while the car sits in the garage.
    https://www.amazon.com/Noco-Genius-7200ma-Battery-Charger/dp/B07G87125Y/ref=sr_1_fkmr0_2?ie=UTF8&qid=1535333054&sr=8-2-fkmr0&keywords=NOCO+Genius+Wicked+Smart+Multipurpose+Battery+Charger%2FMaintainer+-+7.2+Amp%2C+12%2F24+Volt%2C+Automatic%2C+Model+G7200
  6. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Which Odyssey AGM, the 48-720 or the PC1200MJT?
  7. Dave.0
    I forget, but I will check tomorrow.
  8. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    970
    732
    training specialist
    Maysville, North Carolina USA
    So nice to have a stick in situations like that. I have installed two batteries in the last 9 years, both from Advanced Auto. I get their top of the line and watch for tell tale signs.
  9. MCS02
    My last battery from Walmart lasted several years, I think that is whats still in there. I will have to go look.
  10. DneprDave
    I still have the eight year old original battery in my MINI. It hasn't shown any signs of failing yet.
  11. Dave.0
    JINX
  12. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Looking at your old posts, it looks like you got one of the pc1200 extreme series about 3 years ago, I’m guessing the pc1200mjt. Does it have brass posts?
  13. Dave.0
    Yup PC 1200 and I had to buy the brass post separately.
  14. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I have only changed my battery once since new. That was about 3 years ago. It just went. No warning. Car would not start. I replaced with a battery from MINI. Since I get a discount from my dealer, it wasn't more expensive than aftermarket.
    Once a year I plug in my CTEK battery charger to do a desulphate and full charge. Since I got 10 years out of the factory battery, I have no complaints.
  15. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Ordered an Odyssey 48-720 (0752-2020) group 48 AGM battery after sliding my group 47 battery side to side to confirm I have plenty of room for the larger battery.
    Will arrive at my work day after tomorrow in time for the long weekend. Will just have to wait for a brief break in the rainy forcast.
    Not the lightest option at 48#, but what's an extra 10# in a JCW R55 that I already can't keep from going too fast.
    Should last like a tank. 69 Ah, 723 CCA.
    Thanks to all for the posts and advice!
