Belt or Belt Tensioner
Discussion in 'Starting Line - New Member Introductions' started by Texas4Life, Feb 25, 2017.
  1. Texas4Life
    Texas4Life New Member
    Feb 25, 2017
    Military
    Colorado @ the moment
    So first time posting on here, but I have a problem. So on my 04 Mini Cooper S I had a coolant leak. So I changed the water pump, water pump flange, o ring to crankshaft position sensor, o ring to oil dipstick tube, and also changed the oil in the supercharger, since I had it out. So I put everything back on and it went smooth until I went to put the belt on and when I release the tension on the belt tensioner it's not tightening the belt there's a whole lot of play in the belt, enough that I can remove it completely from the ac and alternator pulleys.
    So the question is what happened? Is there something I'm missing, also I made sure the hole was clear in the tensioner, the one that holds it in place. There were no issues before I took the supercharger off.
    It's maybe how you ran the belt around the pulley's . Double check it using the below screen shot.
  3. Canusrufis
    Canusrufis RMW Powered R53
    210
    107
    Winston Salem NC
    ^^^^ I keep a printed version in my glove box in case my O.L.D. kicks in. And an extra belt. It looks trivial until you get in a tight space and start that puzzle.
  4. MCS02
    Also you may want to change the tensioner and idler pulley if this has not been done.
  5. 00Mini
    Might be time for a new belt also.
  6. Texas4Life
    Feb 25, 2017
    Military
    So it was late when I was working on it last night, so I will check the belt route again, but I'm pretty sure I had it right. Also, I just replaced the idler pulley, maybe 3 months ago.
    Just to verify, so there's no adjustment to the alternator and/or the ac correct? Because besides pulling the supercharger out and taking the bolt out of the tensioner that attaches to the supercharger I didn't mess with anything else belt related.
    When I get to work, after my coffee, if I'm still having issues I'll take a picture and post it so show the route and so y'all can see.
  7. Texas4Life
    Feb 25, 2017
    Military
    Well I figured out the belt issue, but now that I have everything put back together, my idle is ridiculously high. Like bouncing between the 1500-2000 rpm range. Any ideas?
  8. Dave.0
    What was the belt issue?
    Plugs, wires or coil.
    It's it out and run it for a little while and let it get warmed up.
  9. Texas4Life
    Feb 25, 2017
    Military
    The belt issue was that I was tired/an idiot and was routing the belt the wrong way lol. So I let the car warm up to normal OT because I wanted to get the air out of the coolant hoses still the idle is high. And I didn't have this issue before so it has to be either a gasket or vacuum line. Just have to find which one.
  10. 00Mini
    Glad to hear that you got your belt problem corrected and Welcome to Motoring Alliance !!
  11. MCS02
    Yea make sure all the vacuumed lines are connected, also make sure all the electoral connectors are plugged in. I have missed a few a time or two. Last time it was the one on the front of the motor by the intercooler.
  12. BlimeyCabrio
    ^ This. Either a sensor or a vacuum line is disconnected.
