1st Gen Belt tensioner snapped OEM
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Razone23, Jan 29, 2018.
  1. Razone23
    Razone23 Active Member
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    Belt is under 10K and didn’t appear to have a damage. Do I need to purchase that belt pulley tool or can I just install a new tensioner. Original tensioner had 110k on it any suggestions on which to buy [​IMG]
    You can replace it without the tool but its a pain in the a$$. If you are keeping the car buy the tool. The tool makes it soooo easy.
    Detroit Tuned has the tensioner for 127.95 and you can rent the tool from them for $20. Amazon has them for $79 or $102. Also Detroit Tuned sales the tool for $85
  3. ScottinBend
  4. Razone23
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    I’d figure that it would be a pain. Order the tool, for future. Thanks
  5. Dave.0
    Yeah that tension has seen the end of its life. That’s why I change it every two years.
  6. Razone23
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    Dave that was never replaced until now, not sure how it lasted so long. Did go with OEM this time
  7. Dave.0
    JB weld FTW..... o_O
  9. MCS02
    JB weld and duct tape they fix anything
  10. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    ouch!
    I change mine every 30k miles.
  11. fishmonger
    May 13, 2015
    984
    769
    Madison, WI
    we must have very similar garages - one tensioner, one idler pulley, 3 spare belts 535 and 532, since two of mine are 15% one is a 17% pulley
  12. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I've changed mine once. Having said that, the original one still looks like it's in perfectly fine shape and can be reused so I kept in as an emergency part. It's probably time for new one on my car anyways. So I would probably go get a new one.
    Those in the Pacific Northwest, particularly on the Canadian side of the border, I am more than happy to lend out my tensioner tool.
  13. Dave.0
