Bentley Manual
Discussion in 'MINI' started by Rangerx, Sep 17, 2014.
  1. Rangerx
    Rangerx New Member
    Jun 25, 2014
    I'm new to my mini his name is MiniMIKE I've been hearing a lot of talking about a Bentley Manuel. Is there not a true mini book then?
    That is the best book for working on your MINI. Its a pro level shop manual. The only thing better is MA:D
  3. Rangerx
    Rangerx New Member
    Jun 25, 2014
    So how would I get my hands on this owner's manual?
  5. Rangerx
    Rangerx New Member
    Jun 25, 2014
    That's a very expensive book dang lol
  6. N2MINI
    N2MINI MINI of the Month
    Dec 4, 2009
    3,349
    575
    Sign Maker
    can also find them used here and there but most go for around 55-75 used..
  7. Dave.0
    Do a search, that was just the first result that came up. I've seen them come up used for less money. Keep an eye out.
  9. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Bentley is a must have, whether you do the work yourself or just want to know how your MINI works (and sometimes doesn't). I picked up a used one for my '06 for $45. Has a couple of fold overs, but perfectly usable. I always make a note in the back of the book of the part numbers for service items such as cabin filter, serpentine belt, plugs, etc.
  10. Dave.0
    And if you order from that link you are also supporting M/A. The site gets a very small cut.
  12. BlimeyCabrio
    So - two points:
    1) if you buy a Bentley manual, get the right one based on the generation / year of your MINI. You didn't mention what year model your car is... the link provided is for 2nd gen MINIs only. There's also a version for 1st gen MINIs.
    2) Just making sure you're not looking for just an OWNER'S MANUAL.... it's not clear from your post whether you're looking for the full shop manual, or just happened to buy a used car that didn't come with an owner's manual? There most definitely is a "Real MINI" owner's manual that comes with the car when new... they can be found in PDF if you search, or you can buy one from the dealer.
    But yes... if you plan to do your own work on the car... the Bentley manual is worth the money.
  13. Nathan
  14. Rangerx
    Rangerx New Member
    Jun 25, 2014
    Thanks Nathan I appreciate it
  15. Jimmest
    Jimmest New Member
    Nov 1, 2014
    There are also service manuals available from Haynes and Chilton. The two are allegedly identical in content. A quick web search will provide multiple sources for each - around $25.
  16. DneprDave
    The Haynes manual is terrible, not just for the MINI but for all makes.
    It is kind of like a movie trailer compared to the Bentley manual's full length feature.
