2nd Gen R56 Cooper S Best Throaty Exhaust
Discussion in '2nd Generation: 2007+ R55 through R61' started by g33kguy, Sep 7, 2012.
  1. g33kguy
    g33kguy The Diplomat
    190
    30
    Professional Geekery a.k.a. User Interaction Desig
    Midlothian, VA
    Okay, I've seen different posts and differing opinions on this topic.
    Here are three exhausts I'm considering.
    Alta 3" Catback
    Akrapovic without the downpipe
    Invidia Catback
    Thoughts on sound between the three? Thoughts on which one is best between the three?
    Thanks in advance for your opinions/thoughts. :biggrin5:
  2. Jason Montague
    :cornut: I have the JCW cat back so no help here but, I haven't heard anything against the brands that you mention. Much more knowledgable gear heads than me should be along shortly.:Thumbsup:
  3. countryboyshane
    countryboyshane New Member
    Jul 23, 2009
    202
    Diesel Engineering
    Bloomfield Hills, MI
    Well you can throw Alta out the window right away. Fitment is not the best and it's not a true bolt on.
    If you want a more throaty sound you need a system that at least gets rid of the useless 2nd cat. Invidia does this and will also be a true bolt on. There are probably plenty of sound clips out there. That is the hot thing to do nowadays. The other true bolt on is the DDM Works exhaust. This is another 3" system that is a true-bolt on solution that uses a Magnaflow muffler with no resonator in the middle. No 2nd cat either! Very deep tone.
    The only thing I don't like about the 3" systems is that it's a little bit overkill on the pipe diameter for this amount of power the N14 engine puts out. If you're concerned with having the lightest option, I would go for the Invidia or a Milltek if you can find one. If I had to do it all over again, I would get a WMW downpipe with a Invidia Q300.
  4. g33kguy
    190
    30
    Midlothian, VA
    What about an Akrapovic downpipe mated to the Invidia Q300? Or is the WMW downpipe of the same quality?
  5. DneprDave
    The Akrapovic down pipe is a high flow catalytic converter. The WMW down pipe is a 2 1/2" open pipe.
    Both are very high quality.
    Dave
  6. g33kguy
    190
    30
    Midlothian, VA
    Thanks for the feedback. The main thing with a new downpipe is avoiding throwing a CEL.
  7. Metalman
    Akrapovic also has a dongle work around that prevents codes from being thrown with their high flow downpipe....
  8. bigfatllama
    bigfatllama New Member
    Jun 21, 2011
    15
    Dubai, UAE
    fJCW exhaust + Evolve De-cat Downpipe.. pops and bangs like hell
  9. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Magna Flow baby, oh wait, this is 2nd Gen. Sorry about that.
  10. bmwr606
    bmwr606 New Member
    May 10, 2012
    62
    25
    i put a milltek on my 2012 cms all4 and am very happy with it
    it has lowered the frequency of the exhaust
    it is a little louder, but not enough to be annoying, even at highway speed
    it has lowered the bottom of the powerband about 1000 rpm, the car makes good power from 2000 rpm and i find i am using 1 higher gear at any given speed
    it has improved throttle response
    great quality
    scott
  11. countryboyshane
    Jul 23, 2009
    202
    Diesel Engineering
    Than you'd want to buy the downpipe code "delete kit" that Way sells. Instead of forking out $300 for this, I would use that money to invest in an ECU tune that can wipe out the cat related CELs along with bringing out the potential of your engine.
  12. mendez
    mendez New Member
    Jan 12, 2012
    26
    Installing a factory JCW exhaust on our 2011 MCS this weekend. Couldn't tell from the post what year/model your MINI is? Did you install the factory JCW exhaust yourself? I have heard it is easy-peasy.
  13. fngolfer
    fngolfer Active Member
    Apr 1, 2012
    100
    46
    Los Angeles
    I installed my invidia q300 myself and I love the deep throaty sound. I just didn't reinstall the crossmember underneath the car because the pipe would sit on top of it and vibrate. It's also the cheapest one available.
