1st Gen Boost/ Vacuum question
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MCS0518, Jan 28, 2018.
  1. MCS0518
    MCS0518 Active Member
    Jan 13, 2018
    155
    175
    The issue I am running into, is I am creating boost. But at the same time, when I get up to around4,000 rpm and above. Sounds like a whistling leaking sound. Just wanted to make sure that maybe it's the green jam gasket? I had ordered one and just haven't gotten around to replacing it.
    Mods currently on the car
    17% pulley
    DDM Works intake
    Invidia exhaust system
    Any help would be awesome!
    Sent from my SM-N950U using Tapatalk
    Um supercharger wine?:D
    I would take a good look at your intercooler boots. The stock ones are the best. If you are going to replace the green gasket I highly recommend a Detroit tuned bypass valve. The stock ones are slow to close and Dont always close all the way. This causes you to lose boost. There is a chance this is your problem. Other than that just check all your hoses and vacuume lines.
    Here’s a link to Detroit Tuned.
    http://www.detroittuned.com/detroit-tuned-bypass-valve/
  3. Dave.0
    Stock rubber intercooler boots +2
  4. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    and if you really want to be certain intake leaks are resolved put one of these on the throttle body, soapy water, and any leak will be revealed. Should be standard issue with an R53 IMO.
    http://turboboostleaktesters.com/new-category-5/
    • Like Like x 1
    • Informative Informative x 1
  5. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Yea - those work well. Watched a buddy use one of those.. helped a lot.
