Suspension Brakes 1st Gen Brake Caliper Bushing Stiffening Kit
Discussion in 'Tuning and Performance' started by Norm03s, Nov 20, 2012.
  1. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Just added a Brake Caliper Bushing Stiffening Kit, Anyone used Super Lube Synthetic grease instead of the recommended anti-seize?
    What ever you use make sure it is high temp stuff. Also lube those once in while.
  3. ScottinBend
    I just use high temp syn grease and service them twice a year....each time I change tires to/from summer to winter.
  4. BThayer23
    Anti-seize works well. It doesn't take much, and it's good because they are dissimilar metals. Lube them at least once a year.
  5. Dave.0
    This ^^^^ :Thumbsup:
    Once for Dragon prep and once when the winter tires go on.
  6. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    We recommend either brake lube grease, or anti seize.
  7. minimark
    Sil-glyde.
  8. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    #8 BRG_Paul, Nov 22, 2012
    I use a mixture of ~30% dry molybdenum disulfide powder and ~70% bearing gel (funky syn grease) from a company called Tom Pacific... Yea, I know, it sounds like a cartoon character .....but the gel is awesome, it's an extreme temperature grease. Plus the moly is a great lube additive.
    http://www.tom-pac.com/
