Exterior 2nd Gen Brake Duct ?
Discussion in 'Tuning and Performance' started by wabiker3576, Nov 15, 2015.
  1. wabiker3576
    wabiker3576 New Member
    Dec 28, 2014
    20
    San Diego
    I keep seeing JCW Brake ducts for sale , but I don't see any difference between them and the ones on the S models .Is there any ?
  2. Metalman
    Need more info...
    What you are comparing....
    Aftermarket or OEM...
  3. cct1
    What do you want them for? If it's looks, it really doesn't matter. If it's function, there are MUCH better aftermarket options.
  4. wabiker3576
    Dec 28, 2014
    20
    San Diego
    The OEM r55's brake ducts vs the OEM JCW brake ducts
  5. BlimeyCabrio
    Is the difference on those primarily how the mate up to their respective bumpers?
  6. Angib
    Here in Yurp there is a bigger-engined diesel Mini, the SD. In the second generation cars, this came with the smaller Cooper brakes but with the working brake ducts of the S. It also came with serious brake fade if the performance and brakes were used seriously, so I'm doubtful that the brake ducts are much more than styling. Making my SD safe to drive fast has required conversion to S discs and aftermarket pads.
  7. Metalman
    The oem brake ducts are not necessarily performance minded. There is a duct passage that continues through to the wheel liner but it is woefully small in cross section. The duct sort of points to the brake disc when the wheels are pointed straight ahead. I think it was done more as a way to be able to wash out debris that might clog up the oem duct at the bumper. If you want functional brake ducts you would need to adapt a kit that brings extra air directly to the discs. Most of our vendors supply this kit....
    OEM Kit.... Really small duct...
    Aftermarket....
  8. Rainman768
    Rainman768 Active Member
    May 3, 2012
    167
    81
    I think it depends on the year. I'd swear that the ducts on the exit side of my LCI MINIs were about 2" x 3". Unfortunately I didn't pay attention when changing my wheels today. :(
  9. Desy232
    Desy232 Banned
    Dec 4, 2017
    10
    For a very long time I was looking for information on this topic. Thanks to all!
