The brake indicator light will not go off after I finished doing the front brakes. The rear brakes still of plenty of pad left. I rechecked to make sure I had the front indicator wire attatched properly, all seems okay. What could be the problem? Thanks for the help.
Was the warning light already on before you did the brakes? If so, the wear sensor would have needed replacement (did you replace it?).
