Brakes Wheels 1st Gen Tires Brake Pads
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by BLUCOOPR, Jun 2, 2009.
  1. BLUCOOPR
    BLUCOOPR New Member
    May 21, 2009
    79
    Retired Truck Driver
    Charlotte, North Carolina
    I have 05 Cooper S with 83K + miles. I was at AMVIV took it in for oil change at 74K and replaced rear pads. Front pads have never been replaced. I was asked if I ever used my brakes and of course I do, but being a retired trucker I had rather downshift. Dealer said I definitely had the most miles he has ever seen on MINI without replacing the pads.
  2. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    That's a lot of miles for sure!
  3. Aeromax
    Aeromax New Member
    Jul 24, 2009
    31
    Graphic designer
    Trumbull, CT
    Wait- 83k and the front pads have never been replaced? Do you ever use the brakes? :lol:
    Even stranger, you replaced the rear pads before the front. They definetly should not have worn quicker. That's odd.
  4. nelson.jones07
    nelson.jones07 New Member
    Nov 27, 2009
    Yeah seems good. You can select this one and enjoy driving with that. Its a nice option for you.
  5. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
    best wear I have heard of
    Although I have seen the rears worn more than the fronts on several occasions.
  6. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    My brakes were changed last year and the rear pads were worn more than the fronts. I Changed pads all around, but I didn't have to replace the rear rotors, but did change my front rotors.
  7. Jason Montague
    Brake Pads/Rotors
    Down shifting instead of breaking. Have you had to change your clutch, pressure plate, and throwout bearing ? Jason :D:popcorn:
  8. bee1000
    bee1000 New Member
    Dec 23, 2009
    176
    Marketing
    San Diego, California
    I had the front-pad warning light come on at around 78,000 miles, so you've got me beat.
  9. lotsie
    stagehand/part time detailer
    Right here
    My 03 justa cooper went 95k miles on the original OEM brakes. Now there is a reason for this. The first 85k miles were 95% highway, 100 miles a day return commute.
    It is also noted by those that follow me on twisties, while they are trying to keep up in their MCS's that my brake lights hardly ever come on:smilewinkgrin:
    At 105k+ miles my original clutch still feels strong:D
    Mark
  10. agranger
    1,486
    You took the question right out of my mouth! As Nathan said recently... brake pads are cheaper than a new clutch.
