Suspension Brakes Brake upgrade help
Discussion in 'Tuning and Performance' started by borv, Aug 31, 2011.
  1. borv
    borv New Member
    Aug 29, 2011
    15
    Hi all,
    I've got a 2011 MCS with the 17" R98 web spoke rims, and want to upgrade the brakes. I want something like the JCS 17" sport brake kit, but according to the website, it will not fit on my car with my current rims.
    Without replacing the rims, does anyone have any suggestions?
    thanks!
  2. beaner
    beaner New Member
    44
    my standard reply to all brake upgrade questions is: call Todd at TCE. he has products that will fit your needs. Great guy, knows brakes, knows MINI fitments......easy.
  3. Todd TCE
    Todd TCE Member
    17"' wheels will allow up to 13" rotors if the proper caliper is used. For a low clearance application the DP6 option makes a great fit to about any wheel!
  4. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    You'll have to get spacers of at least 1/2 inch to make them work together.
  5. countryboyshane
    countryboyshane New Member
    Jul 23, 2009
    202
    Diesel Engineering
    Bloomfield Hills, MI
    So true...
    MINI wheels are very unforgiving with their offset distance if you want to get a big brake kit. I got my MINI with the same wheels and once test fit them on my Detroit Tuned BBK. 15mm was the only way I cleared the caliper. Don't forget to get wheel studs from Way!
  6. Minidave
    4,592
    Are you going to track the car?
    If not, why do you think you need bigger brakes?
    The standard brakes on the MINI are miles above "normal", and I do track my car and haven't run out of brakes yet - so why do you need the upgrade?
  7. ScottinBend
    :Thumbsup:
    .....exactly
