1st Gen R53 Cooper S Brake upgrade issue
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Rocco8788, May 19, 2015.
  1. Rocco8788
    Rocco8788 New Member
    Feb 19, 2012
    41
    Pittsburgh, PA
    So over the past 2 weeks I Have done a few little things for my R53. (takes a big breath) Left front axel, Right front axel, Wheel bearings all around, Left and Right lower control arm bushings, new thermostat housing, new lower control arm ball joints, new inner and outter tie rods, and yes, breaks all around. The breaks I did are Stoptech slotted (not drilled) rotors with stoptech posi quiet pads. Initial bite is wonderful and they stop well mostly. Last evening on my way home from work at 3AM I ,we'll say, got a little frisky and ended up with a ton of fade and some warm smell from the frontal area. The fade came on suddenly. There was little warning.
    Has anyone else ran these pads and are the just inferior or is it the fluid/rubber hoses that's the issue. I used to have a 96 jetta thyat I ran harder than this and had no fade ever with CRAP for brakes that were smaller on a heavier car. Any sugestions short of a BBK will be helpful.
    Were they bedded in properly? This last little frisky run my have accomplished that for you.
  3. mrntd
    I had the Stop Tech pads I did get a little fade but my complaint was the lack of initial bit. I changed to Akebono pads and they are great.
    Now the other thing. I found that my brake lines were deteriorating. I didn't notice it until I flush the fluid. I had a thin dark stream in the fluid while bleeding. I changed the to the Stop Tech breaded steel lines and bled the system again. The dark stream was gone. My car only has 39k mi but it is 10 years old.
    You may not have to go with the breaded steel lines. But new lines could be a good idea. That and a fluid flush.
    How old is your brake fluid? Brake fluid absorbs moisture over time which lowers the fluids boiling point. This can lead to all sorts of fun! Replace your fluid, bed the pads in again & I think you'll be good to go.
    I doubt it is your rubber brake lines, but getting a set of SS ones on might not be a bad idea. Now is the time since you are going to change the fluid.
  5. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Start with a good fluid flush, and double-check your installation (make sure the pads are moving in the carriers). If you still are having problems, I would switch to the Hawk HPS pads. I'd have to respectfully disagree with the Akebono suggestion: I've found them to perform poorly with soft bite.
  6. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    I just did this - fluid, SS lines. Highly recommend one of these Motive bleeders when flushing fluid. Super easy. So easy I felt like brake flushing all my cars. Like a brake flushing party man.
    Brake Fluid Power Bleeder - Way Motor Works
  7. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    you know you can buy that exact tool from other places for cheaper.
  8. Rocco8788
    Feb 19, 2012
    41
    Pittsburgh, PA
    #8 Rocco8788, May 21, 2015
    Thanks guys. I was thinking flush and lines myself but I wanted to see others opinions. I never had the system open therefore I never bled it and as far as I know, everything is original, so the lines/fluid/everything is now 12 years old and 146k on it. there's no shame for it.
    What fluid have you used?
  9. Nathan
    Oh my, yes, you do need to do a full flush. Every two years is MINI's schedule. Annual is even better.
    Your brake system is not sealed so it doesn't mater if you've never opened it. Moisture gets in. Besides lowering the boiling point the moisture gravitates to the lowest part of the system, the calipers. So beside boiling the fluid you can rust the pistons in the calipers.
    I've used ATE & StopTech fluid. If you are not tracking ATE should be fine. Lots of good fluids out there.
  11. ZippyNH
    Any DOT4 fluid is fine if you are not tracking the car....
    Get that SOB bleed....the fluid is spent...
    You are lucky it did not make the seals in the caliper gummy and let them leak, or worse yet corrode , then tear the sesls... Or have the abs/DSC/asc pump fail...
    Keep it bleed every 2 years...things can get $$ if you don't...
  12. Rocco8788
    Feb 19, 2012
    41
    Pittsburgh, PA
    On further inspection the rear calipers have been replaced. The fronts appear to have not been. This coming week I will get the old out and in with the new. So no silicone fluid?
    NO! Do not use silicone fluid.
  14. Dave.0
    Ummmm I have no problem keeping up or stopping on the Dragon with my Akebonos. :lol::ihih::lol:
    OP have or brakes flush / bleed your brakes every year.
  15. mrntd
    You can get the ATE on Amazon for a great price.
  16. Eric@Helix
    1,257
    Shepherd
    Philadelphia
    Well then you're not pushing your car, Capt. Slow.:devil:
  17. Dave.0
    #17 Dave.0, May 22, 2015
    Well I was right behind Marzo "Mr. Look my rotors glow" on the Dragon. :lol::ihih::lol:
    Maybe you can take me for a ride in your RSR 911 and show me on the Dragon in 2020. :devil:
    Say "hi" to Ryan Chucky. :prrr:
  18. vetsvette
    I installed Stoptech drilled and slotted rotors, pads, and SS lines last fall. Flushed and bled the system before taking it out and bedding the pads and rotors. No problems with fade since then. I used a Motive Products Power Bleeder and Pentosin DOT4.
  19. ZippyNH
    While I never used my car on the dragon....
    I can say the akebonoo's were good as long as they were used hard REGULARLY....
    I went about 2000 miles of very gentle braking due to tons of snow....and they felt like crap when the roads cleared till I basically burnt them in again.....
    My guess is while they are dustless, light use might reduce their bite....so if you regularly use them hard, they stop good and are dustless!!
  20. Dave.0
    ^^^^ exactly. Warm then up and they have great bite. Also they are not dustless when pushing them hard on the dragon but they don't fade either.
