1st Gen R50 Cooper Brand new Serpentine Belt squeal when cold
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Different Computers, May 20, 2014.
  1. Different Computers
    Different Computers New Member
    Apr 7, 2014
    171
    68
    Mac Guy
    Troy, VA
    One of the maintenance issues necessary when I bought Black Top used ('03 R50 91K miles) was a serpentine belt replacement. It also needed a new belt tensioner.
    After that replacement, when I start the car cold (not air temp, cold as in cold engine) I get a belt squealing noise for a few moments, apparently until the belt warms up. I have a suspicion this is also related to damp weather, but I'm not sure.
    Anyone else experience this? Should I care? Should I take it back to the place that did it to have them check the tension?
    I have has that happen from time to time when it really cold but then again my car lives in a garage.
    It could also be your idler pulley loose if it still the original one. (cheap fix)
  3. Different Computers
    Apr 7, 2014
    171
    68
    Mac Guy
    Troy, VA
    Thanks! The odd thing is there wasn't any squeal from the old belt. But then, almost the first thing I did was get the belt changed.
  4. Dave.0
    Who is the maker of the belt? I use Gates belts.
  5. ScottinBend
    ....and make sure it was put on the right side out. Done that....:mad:
    At your mileage I'd change out the idler for sure. Also have a good look at the crank damper pulley. Not sure if a failing pulley would cause that noise. It is odd you went from no noise to noise with a tensioner & belt change.
    I used to get that once in a great while, but since all all those parts were replaced on mine the sound has been absent.
  7. Different Computers
    Apr 7, 2014
    171
    68
    Mac Guy
    Troy, VA
  8. Dave.0
    Did you oil the belt? JUST KIDDING.....good luck
