Brighter Reverse Lights
Discussion in 'General Technical Questions and Answers' started by caseydog, Jul 30, 2019.
  1. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    With the dark window tint on the rear of my car, the weak reverse lights do very little for me. Are there brighter replcement reverse lights available -- probably LEDs?
    CD
  2. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    #2 cristo, Jul 30, 2019
    I used to use a 796 35W halogen bulb as a
    reverse light, about twice as bright as stock,
    but recently found a better, even brighter option.
    I also have tinting on the rear window as well
    as only one reverse bulb by design (2009 Clubman).
    Here’s my post from last April:
    Put a high power LED Bulb in the
    reverse light socket (only one on the
    right in my R55, so it needs all the help
    it can get).
    About 4-5 x as bright as a p21w and
    more than twice as bright as the 796
    35w halogen bulb I usually use in that
    position.
    Manufacture claims 3600 lumen and
    1800 mA draw per bulb, but I measure
    about 1800 lm and 850 mA. 6500K.
    I like 3.5-5K better but no one makes a
    bright one like that that I could find.
    https://www.amazon.com/Boodlied-20Watts-3600LM-Bright-Reverse/dp/B07DZS4TPT/ref=mp_s_a_1_fkmrnull_1_sspa?keywords=boodlied+3600lm+1156&qid=1555852951&s=gateway&sr=8-1-fkmrnull-spons&psc=1
    Do you get a bulb out error using that LED? Or does it have a resister built in?
  4. cristo
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    No bulb out error, but I don’t think the
    reverse bulb gets checked by the
    system in an R55 like just about
    all the other bulbs do.
  5. ScottinBend
    I would be worried about the heat.
  6. cristo
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    #6 cristo, Jul 30, 2019
    The 35W 796 halogen bulb does run hotter than the stock 21W bulb,
    but the reverse light is seldom on long enough for that to make a meaningful difference.
    (Increased heat is a valid concern as the MINI tail light assembly has been known to
    melt plastic and weld the bulbs into the holders with even stock bulbs in some cases).
    I can't guarantee that 35W won't stress the BC1 but I doubt it would. I never had a problem.
    The Boolied LED lights actually run cooler than stock -
    they draw 850ma at 13.5V which is about 11.5 W, so no worries there.
    I know they're listed as 20W, 1800ma and 3600 Lumens per bulb on the Amazon link,
    but all those numbers are about double what I measured with a Gossen light meter and
    Fluke multimeter. I'll bet the description is supposed to actually reflect specs for a pair of bulbs.
    I'm pretty sure LED lights have less heat than incandescent bulbs.
  8. ScottinBend
    Usually, but most are increasing the brightness and associated heat. Look at most of the LED headlight conversions.......huge heat sinks are needed.
  9. Dave.0
  10. 00Mini
    Nice find Dave.
  11. MCS02
  12. cristo
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    LEDs need more heat dissipation than
    incandescent bulbs because filaments
    are designed to work at extremely high
    temperatures and LED elements are not.
    Well you learn something everyday. Keep that knowledge coming folks. It takes a while until it penetrates my thick skull & sinks in.
    I like that LED backup light you found Dave. In the olden days I'd justa slap a big Hella fog lamp on the rear bumper. :)
  14. MCS02
    I thought of doing that to my truck. Not really for backing up, it has a great camera, but for the jerks that think they need 10 light bars on their trucks and run them all the time.
    • Funny Funny x 4
    • Like Like x 1
    Make sure you hook that back up light to the reverse switch. Some night you may turn it on & light up a cop who then lights you up. LOL
  16. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
  17. rkw
    rkw Well-Known Member
    443
    Heat dissipation is important for LEDs that are constantly on for a long time, such as headlights and running lights, but not as important for brief usage such as reverse lights.
  18. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    This sounds like what I am looking for. I just wonder if your Amazon link will be for the right replacement bulb for my R56 MCS? I did some searches, and could not come up with any kind of replacement guide.
    CD
  19. cristo
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    #19 cristo, Aug 1, 2019
    It looks like the R56 uses 921 reverse
    bulbs rather than the 7506/1156/p21w
    type that my R55 does as well as my
    previous R50 did.
    Sorry if I led you down the wrong path.
  20. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    Hey, no problem. At least I know there may be some options. I just need to search harder.
    I have two reverse lights, built into the taillights on my R56 MCS. I am thinking there has to be an LED replacement. Those reverse lights were not great, even without window tint.
    Thanks for your input.
    CD
