1st Gen R53 Cooper S Broke Cam??
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by maacodale, Jan 24, 2015.
  1. maacodale
    maacodale Club Coordinator
    255
    Poquoson, VA
    Daughters MINI died yesterday. Apparently, the cam broke between cylinders 1 &2. This after the head has been off twice since June. Last time was 8 new valves. It all started with low compression in #2. And I thought my 07's issues were enough to drive the crazy!
    Don't think I've heard of many cams breaking. By the way it's an automatic and she really doesn't dog the MINI much. Me....maybe, but I don't get to drive it much.
    That is very odd, but good luck with getting it fixed.
  3. MCS02
    Thats very Odd. Did a rebait shop do the work?
  4. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Is that a stock cam?
    Never heard of a stock cam breaking, aftermarket yes but OEM, never.
  5. maacodale
    255
    Poquoson, VA
    Yep, stock cam, work done at the dealer. I could see it in my MINI ore maybe even the wifes Clubman. I run those pretty hard. But the daughters Cabrio really doesn't get run hard at all. Getting kinda over this little car to be honest. I'm sure the warranty company is tired of it as well.
  6. MCS02
    I bet the cam was the problem the hole time. I don't care how hard you run a car you can't break a cam. I have seen cams go bad because of wear for different reasons but not break!
    This should be a free fix warranty or not!
  7. Dave.0
    ^ yup I agree with that, it's free fix time.
  8. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Only time I personally heard of a cam snapping in two for no good reason was a friend
    with a Renault LeCar - about 35 years ago. Renault denied it was a manufacturing
    fault even though the car was completely stock and had only easy daily driver use and
    the head had never been worked on.
    On the other hand, not a car known for good quality control and reliability.
  9. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    Vacuum pump didn't seize, correct?
  10. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    I have actually seen a few cam's break on the gen 2 motors. It always comes back to lack of oil and the extended oil changes that MINI recommends.
  11. MCS02
    What is causing it? Is it running dry and seizing the cam?
    Saving a few buck on an oil change can get quite expensive me thinks. :eek6:
    My guess is the oil galleys are getting plugged up with sludge fudge. Fudge is tasty, but a poor lubricant.
  13. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    If things don't have lubrication, they get hot and the ends of the cam can break off due to the end being hollow for the bolt as well as the weight and tension on the end due the timing chain.
  14. Mr. Jim
    Is it at WMW now? Saw on FB he posted a picture off a broken cam and said it was a auto with low mileage.
  15. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    ^Yup^
    Never seen a snapped cam here from any generation of MINI.
  16. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    I've seen cams get taken out by seized vacuum pumps as well.
  17. Dave.0
    The last time a broke a CAM was when I swung it against a mailbox.
  18. Metalman
    Brokeback Cam...
    Didn't they make that into a movie....
