BWM and EPA in conflict
Discussion in 'MINI' started by Rixter, Oct 15, 2010.
  1. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
  2. Metalman
    I have a real hard time finding 0% Ethanol gasoline now.:mad2:
  3. Justa Jim
    The only 0% Ethanol near me is CITGO which is not a high tier brand, but if this happens I may have to try it.
  4. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    #4 Rixter, Oct 15, 2010
    Try Pure-gas.org. Its a community driven site where people post locations without Ethanol. If you find a station, be sure to add a post. :Thumbsup:
  5. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    The sad thing happening is E10 might become the de-facto standard and gas companies will no longer have to tell you there's 10% ethanol in the fuel.
    That's about the same thing that happened when unleaded gasoline came in. over time regular gasoline was unleaded. Those driving 15 year or older cars had to either do some mechanical work on their engines or use lead additives. I notice that in some gas station in various states already. Even here in BC, the 10% ethanol label is in fine print at some stations and you really have to hunt for it to see it.
    For now, I believe the law is for E15 to be a separate pump and for 2007 or newer cars. Mostly for American cars, which are "E85 compatible". This is how they got their higher EPA rating than real world gas mileage.
  6. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    I confirmed today that Shell V-Power 91 along with the Chevron 94 is E-free. We can do our small part by supporting these manufacturers and showing that there's a demand for E-free gas.
  7. Metalman
    Very interesting....
    I checked in with your Pure-gas.org. Nothing listed for Columbus, Ohio. Ran copies of the print-out for each state so I can make my gas stops on my trip to the Dragon next week.
    I normally buy Shell V-Power, but it's generally very difficult to find any kind of notice about being E-free at the pumps. Asking the kid plugged into the I-pod, behind the bulletproof cashiers station generally results in a blank stare, so I'm never really sure.:incazzato:
  8. Justa Jim
    I use V-Power 93 and all the stations around here a E10, sadly. Where did you see it was E-Free??
  9. Justa Jim
    Chuck, 129 runs on from Deals Gap, for a few miles to Robbinsville. Just before you get to town is a Chevron Station. :Thumbsup:
  10. Metalman
    Yup.....
    Thanks!
    Saw that on my printout I'm taking with me.:D
  11. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    I emailed Shell (Canada) to get confirmation. Chevron states it right on the pump with as sticker on their 94 that says "Ethanol Free". WRT Shell, I'd email them and find out for your area/state if their V-Power is E-free. Apparently it can vary in differnent parts of the county
  12. Justa Jim
    Thanks. I will do just that.
  13. vereinmann
    vereinmann New Member
    Aug 12, 2010
    9
    I emailed Petro-Canada a while ago, their 91 is for sure E-free in Ontario
  14. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    In the US
    gas composition varies at least by state, and maybe even by region within a state. Be very carefull with blanket statements that Brand Y is ethanol free. It may be where you live, but probably isn't everywhere.
    Matt
  15. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    That can change market to market. The Shell VPower does have 10% here in most stations I stop at
  16. DneprDave
    It varies from state to state. Here, it is required by state law that the ethanol content be prominently displayed on the pump. The only place I know of locally that carries non-E gas is a card lock place in town, and it isn't premium gas. Everywhere else it's 10% ethanol.
    I have a bunch of old English cars, from before unleaded gas was required. I have had no problems running unleaded gas in them. The warnings about valve seat recession, when using unleaded gas, turned out to be unfounded.
    Dave
  17. YeloMini
    YeloMini Member
    Jul 7, 2009
    234
  18. ZippyNH
    One thing that will limit the speed of the roll-out of e-15 (Thank GOD) is that 99% of the current fuel pumps in use are only UL approved up to 15% ethanol....and pumping 15% with a 15% approved device is not considered safe for by most owners....if a blending error or settling occurs, damage to the pump, the hoses, leakage, or even an explosion could happen.....
    This is one reason why it has been stated that it may be separate pumps/tanks that many stations will use to sell E-15. As newer pumps are sold, I'm sure they will be compatible, but for a few years, widespread E-15 is unlikely!!
  19. MiniKar
    MiniKar Member
    Sep 24, 2010
    62
    Nevada
    I say lets buy a gas station, and sell pure gas only !
    We may have to charge alittle more but its Pure Gas ! ! !
  20. Metalman
    Sooooo.......
    On the way down to MSSD from Columbus, full tank of gas (some mixture of 93 octane with 10% Ethanol and with 0% Ethanol). Got 34.7 MPG.
    Return trip from MSSD back to Columbus (93 octane. 0% ethanol). Got 37.2 MPG.
    Both trips similar air temps.
    Note: MPG Calculated by "optimistic" MINI on board ECU.
